Complicated Catapult/Conservation of Energy Test Question
  • Thread starter Thread starter ccmuggs13
    Energy Test
The discussion revolves around a physics test question involving a catapult's energy dynamics. The main confusion lies in determining the correct compression of the spring when calculating elastic potential energy, with some participants debating whether to use linear or angular distance. The spring constant is confirmed to be 2000 N/m, and the equilibrium position is defined as that of the spring. Participants emphasize the importance of considering both gravitational and spring potential energy to find the kinetic energy and velocity of the rock. Ultimately, the calculations suggest that the arm may not return to equilibrium unless it is pulled down significantly before firing.
ccmuggs13
I just took a physics test today and there was one problem that I cannot figure out if I did correctly. The problem involves a catapult pictured here: http://i39.tinypic.com/a2t76h.jpg
The bar is 2m long and has a mass of 3kg. The rock at the end of it has a mass of 5kg. The spring is .3m from the pivot. As shown, when the spring is unstretched/uncompressed the bar makes an angle of 30° above the horizontal. It is then pushed down so it now makes an angle of 30° below the horizontal. My first question is what is the x for the spring when determining the elastic potential energy? Because I just set up triangles and figured it out to be .3m but my friend used the relationship between linear and angular distance, d=θr, and got x to be larger. But I believe that gives the arc length traveled by the end of the spring as it is compressed rather than how much it is actually compressed but I could be wrong. Here is a picture of what I think it is like: http://i44.tinypic.com/5zm6om.jpg
And so after you figure out what x is, what the problem asks for is the velocity of the rock as it passes back through the original position? (Using conservation of energy) So how would this be done and what is the answer? Because I ended up with a negative value while trying to find the answer meaning the spring did not have enough energy to get the catapult back to the starting position but this is probably wrong because that would be a dumb test question. Sorry this post is so long but please help! I've been going nuts trying to figure out what I did wrong!
The displacement would depend on where the other end of the spring is attached. If it's right bellow the point where it's attached to arm at equilibrium, your value of .3m is correct. I would go with that given no other information.
Do you happen to remember what the spring constant is? Also, is the equilibrium position equilibrium for the spring, equilibrium for unloaded catapult, or equilibrium for loaded catapult? Each of these would give you different results. In the final case, the speed will be maximum through equilibrium. But in the first two cases the kinetic energy might work out to be negative if the spring coefficient was too low.
The gravitational potential energy as function of angle looks like this.
U = sin(\theta)\frac{1}{2}mgL + sin(\theta)MgL
Kinetic energy as function of velocity.
T = \frac{1}{6}mv^2 + \frac{1}{2}Mv^2
Where L is the length of the arm, m is mass of the arm, M is mass of the boulder, and v is velocity of the boulder. The angle is measured from horizontal.
Assuming equilibrium is equilibrium for the spring, the rest is easy. Add spring potential to gravitational potential at lower point, subtract of gravitational potential at the equilibrium point, and that's your kinetic energy. Solve for v, and you're done. If some other equilibrium condition is meant, you'll have to correct for it.
Oh yea I completely forgot about the spring constant, it was 2000N/m. And the equilibrium position is equilibrium for the spring.
Also can you use the linear kinetic energy formula for this? Because a large portion of our test involved angular velocity and the problem gave us a hint reminding us of the formula for the moment of inertia of a bar about its end so I assumed we needed to use angular velocity and kenetic energy and such.
Oh I think I see that you did take angular motion into account as opposed to just linear which is why you have the kinetic energy of the bar start with 1/6 as opposed to 1/2
But unless I am doing my calculations wrong I am still getting a negative kinetic energy... Please check the calculations. This is a very dumb question if the spring really does not have enough energy to return to equilibrium
I think x=2(.3)tan30° since Cos30°=-Cos30°
If you remembered all the numbers correctly, and the equilibrium is equilibrium for the spring, you are absolutely correct. Here is a plot of kinetic energy as function of angle. The points where the curve crosses zero are turning points. The angles are in radians. So the arm will get just a little past 0°, and then start coming down again, never reaching the equilibrium point. To get the arm to swing past equilibrium, you must pull the arm down past -60° before firing.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
