Complicated path question - 2D vectors
  • Thread starter Thread starter Kawakaze
    2d Path Vectors
The discussion centers on a physics problem involving a model car's motion represented by a 2D vector function. The participants express uncertainty about the physical significance of the position vector and how to determine maximum distances using its derivative. They acknowledge that the car passes through the origin twice within the specified time interval but struggle to prove this mathematically. For velocity and acceleration, they note that differentiation is straightforward, while calculating when velocity is perpendicular to displacement poses a challenge. The conversation highlights a need for examples and clarification on these concepts.
Kawakaze
A model car of mass m moves on a horizontal track so that its
displacement r from a fixed origin at time t is given by
r(t)=2cos(t)i + sin(2t)/sqrt2j where 0<t<2pi
(a) If r is the position vector of a particle, explain the physical
significance of r . r and show how d(r.r)/dt can be used to determine
the maximum distance of the car from the origin.
(b) Show that the car passes through the origin exactly twice in the time interval and determine the two times.
(c) Determine the velocity and acceleration of the car at time t.
(d) Determine the times at which the velocity of the car is perpendicular
to its displacement and the position vector of the car at these times.
(a) Unsure of significance, but its pretty clear that when d(r.r)/dt = 0 you have your maximum and minimum distances from the origin.
(b) No idea how to prove this but I guess its obvious that you would have two solutions in the interval 0<t<2pi.
(c) No problem, differentiate once for velocity and twice for acceleration.
(d) This looks like a fun part, but no idea how to calculate this. You want the vectors to be at 90 degrees to each other.
Help please! :)
Remember that two vectors are perpendicular when their dot product is zero.
I know this is what i need to do, is there any worked examples online you know of?
Also still no idea about part (a)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
