Compressed Air Pressure Drop Across a Restriction
In summary, the individual is looking for a formula to describe the reduction in pressure when compressed air travels through a bell reducer in a piping system. They also inquire about the effect on pressure if the flow rate is doubled and the availability of a textbook for non-engineers on the physics of compressed air. Another individual recommends the Crane technical paper 410 as a valuable resource for fluid flow in both liquids and gases. The original individual expresses gratitude for the suggestion and plans to use TP 410 as a starting point for their research.
SteveRomero
I would like the formula that describes the reduction in pressure that results when a constant flow (cfm) of compressed air travels from a 3" diameter pipe through a bell reducer that provides a smooth transition to a 1.5" diameter pipe.
Also, in the same piping configuration as described above, if the pressure drop is X psid acress the reducer, what will the pisd be if the cfm were doubled? What is the formula for this relationship as well?
Is there a textbook that is available for non-engineers that describes the physics of compressed air in industrial compressed air systems?
Thanks a million.
This is probably your best bet:
http://www.flowoffluids.com/tp410.htm
CS
Thanks . . .
. . . CS, for your help. The publication that you identified appears to be specifically for liquid fluids . . . I need compressed air information. Do both liguids and gases follow the same physics?
Hi Steve,
The book stewartcs points out (Crane technical paper 410) is the bible of the industry. Process work throughout industry relies on it for fluid flow through piping systems. The paper specifically calls out where it is applicable and where not, so yes, it's applicable to compressed gas systems.
SteveRomero said:
Thanks . . .
TP 410 does include gas flow as well as Q pointed out. It would be a great place for you to start.
CS
Thanks again. Crane TP 410 is where I will begin my search.
Steve
Related to Compressed Air Pressure Drop Across a Restriction
What is compressed air pressure drop?
Compressed air pressure drop refers to the decrease in pressure of compressed air as it flows through a system or component.
Why does compressed air pressure drop occur?
Compressed air pressure drop occurs due to the frictional resistance and turbulence within the system. This can be caused by obstructions, restrictions, or changes in direction of the air flow.
What is a restriction in a compressed air system?
A restriction in a compressed air system is any point where the flow of compressed air is impeded, leading to a decrease in pressure. This can include narrow pipes, fittings, valves, or any other components that cause a change in the flow path.
How is compressed air pressure drop across a restriction calculated?
Compressed air pressure drop across a restriction is calculated using the Bernoulli's equation, which takes into account the initial pressure, flow rate, and the resistance of the restriction. It can also be calculated using the Darcy-Weisbach equation, which considers the length and diameter of the restriction.
What are the effects of compressed air pressure drop across a restriction?
Compressed air pressure drop across a restriction can lead to decreased efficiency and performance of the system. It can also cause excess energy consumption, decreased air flow, and potential damage to equipment. It is important to minimize pressure drop in order to maintain optimal functioning of a compressed air system.
