Compression of Compressed Fibre Gaskets: Is it Linear?
  • Thread starter Thread starter James3849
    Compression
The discussion focuses on the compression characteristics of compressed fibre gaskets and whether their compression is linearly proportional to the applied stress. Participants emphasize the importance of understanding gasket compression for ensuring proper sealing in flange applications, especially under operational conditions. They note that gasket materials can vary, and some assemblies may require specific torque sequences and "torque to yield" bolts for optimal performance. There is a call for stress/strain curves for different gasket materials, as vendors often do not provide this proprietary information. Resources such as McMaster-Carr and Flexitallic are suggested for obtaining gasket specifications and additional information.
James3849
Hi All,
I am currently researching required bolting torques for flanges on a large water pipeline, but my question relates to compression of compressed fibre gaskets.
I know that catalogues and vendors typically specify the percent compression under a specfic test stress, and also percent recovery. What I would like to understand though is, is the amount of compression directly porportional to applied stress (i.e. linear) or can we assume this is so, or a is it slightly more complex?
I need to know this to ensure a proper seal in the flange, espcially under full pipeline operation.
Cheers
i do not know and it varies...typical gasket material is uniform. but..in any gasket application involving bolt patterns there is a specific torque sequence. on a cylinder head it is a cork screw pattern starting with the bolt located in the center of the head and spiraling outward. i recommend you measure the gasket thickness and tork down the gasket to actual specs. unbolt the assembly and measure the gasket for crush.
some gasket assemblies use "torque to yield" bolts. they maintain the proper compression on the gasket by being in "stretch mode". these kind of seals require the replacement of the bolts if disassembled. additionally, many gaskets are not a single material, but a sandwich of multiple layers. the layers composition determine its compression requirements.
dr
being in the design phase of the project, we don't really have the luxury of testing gaskets for compression at different bolt torques. We are currently undertaking an investigation into selecting the most appropriate gasket for the job and need to model effect of gasket compression and recovery during full operating conditions.
what would be extremely useful would be stress/strain(compression) curves for different gasket materials.
although from what I've found from vendors, they don't have this information readily available as they tend to deem it proprietry knowledge.
Does anyone know where I could find any characteristic curves for gaskets, particularly for compressed fibre gaskets?
Flexitallic has a lot of information. I design high temperature equipment and use a lot of their thermiculite gaskets and the spiral wound gaskets.
Here is some information on the compressed fiber gaskets.
http://www.flexitallic.com/pdf/broCompFiber.pdf
Also, regarding bolt torque see the ASME (American Society of Mechanical Engineers) section VIII division 1 or 2 for their method of flange design.
Thanks
Matt
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
