Compute Solid Angle of Cone: θ | Hi Everyone
  • Thread starter Thread starter azerty12
    Solid
To compute the solid angle of a cone with a known apex angle θ, the correct approach involves using double integration. The integral should be set up as ∫₀²π ∫₀θ sin(θ) dθ dφ, ensuring that φ is integrated from 0 to 2π. A common mistake is to incorrectly set the limits of integration, such as using -θ instead of 0 for the inner integral. The discussion highlights the importance of correctly applying the integration limits to achieve the right result. Understanding these details is crucial for accurately calculating the solid angle of a cone.
azerty12
Hi everyone
I'd like to compute the solide angle defined by a cone whose angle θ is known.
I tried with the definition but I probably mistook since it lead me to compute an integral worth...0.
I then tried with a rule of three, but the result I get is clearly wrong too.
Could you explain me how to proceed?
Try this:
\int_0^{2\pi}\,\int_0^\theta\,sin\theta\,\mathrm{d}\theta\,\mathrm{d}\phi
for a cone with apex angle 2theta
via wikipedia
Thank you emgram769: In fact that's almost what I tried to do but I took the second integral with -theta instead of 0 (and we should take 0 because phi is integrated over 2Pi)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
