MHB Compute the downwards flux of F
  • Thread starter Thread starter Uniman
    Flux
The discussion focuses on calculating the downward flux of the vector field F over a specified surface S. The vector field is defined as F(x,y,z) = i cos(y/z) - j (x/z) sin(y/z) + k (xy/z^2) sin(y/z). The downward flux is expressed as a double integral involving the component of F in the k-direction, specifically simplifying to the integral of xy sin(y) over the surface where z=1. The user is encouraged to proceed with the calculations based on the provided setup. The conversation emphasizes the importance of correctly interpreting the vector field and surface for accurate flux computation.
Uniman
Mathematics news on Phys.org
Uniman said:
https://www.physicsforums.com/attachments/418
The work done so far
https://www.dropbox.com/s/qmfidqot3nttlw5/phpQd8GGH.png
https://www.dropbox.com/s/xn4t5m2aleopwy7/phpldZ0KX.png
Is the answer correct...
Hi Univman, :)
The links to your work on the problem seem not to work. Anyway, you have been given the vector field,
\[\mathbf{F}(x,y,z)=\mathbf{i} \cos\left( \frac{y}{z}\right)-\mathbf{j} \frac{x}{z} \sin \left(\frac{y}{z}\right)+\mathbf{k} \frac{xy}{z^2} \sin \left( \frac{y}{z} \right)\]
The downward flux of \(\mathbf{F}\) over \(S\) is given by,
\[\iint_{S}\mathbf{F}.(-\mathbf{k})\,dS=-\iint_{S}\mathbf{F}.\mathbf{k}\,dS=-\iint_{S}\frac{xy}{z^2}\sin\left(\frac{y}{z}\right)\,dS\]
On the surface \(S\); \(z=1\). Therefore we have,
\[\iint_{S}\mathbf{F}.(-\mathbf{k})\,dS=-\iint_{S}xy\sin y\,dS=-\int_{x=0}^{1}\int_{y=0}^{\pi}xy\sin y\,dy\,dx\]
Hope you can continue. :)
Kind Regards,
Sudharaka.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
