Compute the position of the sandbag
  • Thread starter Thread starter cuttie2nv143
    Position
To compute the position of the sandbag 0.330 seconds after release, the user attempted to use the equation x = xo + voxt + 1/2axt^2 but is struggling to find the correct answer. Other participants suggest posting the question in a homework forum and providing a detailed attempt to facilitate assistance. They also recommend improving the thread title for better visibility and engagement from potential helpers. Clear communication of the problem and showing work are emphasized as crucial for receiving effective help. Engaging with the community in this way can lead to more productive discussions and solutions.
cuttie2nv143
compute the position of the sandbag at a time 0.330 s after release. v=5.00m/s & h=40.0m. i have tried using the equation x=xo+voxt+1/2axt^2, but i still can't get the answer.
I would suggest two things. First, that this be posted in the homework forum, and second, that you show us your attempt, and then we'll be more willing to help you.
yeah show us your work so we can help you..
Also, it may be better in future if you put in the title of your thread something that related to the question, since then when helpers are scanning through the list of threads, they will know whether they are able to help or not. (It's really in your best interest, since you will then get more people looking into your thread :smile:)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
