Concentric circles are parallel?
In summary, the conversation discusses the concept of parallelism, specifically in relation to lines and curves. The usual definition of parallel in Euclidean geometry only applies to straight lines, but there are other definitions that include curves. The key characteristic of parallelism is maintaining a constant distance between two objects, regardless of whether they are straight lines or curves. However, the understanding of parallelism is limited by humanity's focus on straight lines, making it difficult to understand non-Euclidean geometries. There is a need for a more inclusive definition of parallelism that recognizes its presence in natural phenomena.
  • #36
Ya-all quite pickin' on phya. You all should know better. Good grief!
Normally, phya, in the way these things are taught, right or wrong, a vector or a line is independent of the coordinates in which they are described. It's really a matter of convention. In this convention, we assume that a line is independent of the coordinates, such as x,y and z by which we measure its parts. It has an existence of it's own, and the coordinates are a matter of choice.
You, on the other hand, are taking the opposite view. You take two parallel lines and wrap them in a circle. You are taking the coordinates as fundamental and the line is a mutable object.
In your system x-->radius and y-->an angle, so that parallel lines in in (x,y) are still parallel. There's nothing wrong with this, it's not the convention so people get confuse, but it certainly not wrong--just different, and a perspective that may have great value.
Mathematics news on Phys.org
  • #37
“crosses outside the straight line a spot to have two straight lines and the known straight line at least parallel”, I believed that non-Euclid geometry's this view is wrong. Because, first, in the non-Euclid geometry's straight line is not in the Euclid geometry straight line, second, does not intersect was not equal to that is parallel, does not intersect regards is parallel, this has confused parallel and not the parallel concept. If we regard the circle the straight line, then may also say: Crosses outside the straight line a spot to be possible to make the innumerable strip straight line (this passes through known point, but does not intersect with known circle these circles) do not intersect with the known straight line.
  • #38
phya said:
“crosses outside the straight line a spot to have two straight lines and the known straight line parallel non-Euclid geometry some views is at least” wrong.
Who are you responding to?
  • #39
My this reply not in view of anybody.
  • #40
I was just trying to understand the quotation marks (and, for that matter, the quotation).
  • #41
What not clearly do you have?
  • #42
Like the chart shows, nearby one rectangular plane's about two is parallel, if we become this rectangle uniplanar bending the proper circle barrel, nearby rectangular about two becomes two curves, ask that by now these two lines no longer were parallel?
  • #43
About curve parallel and non-Euclid geometry mistake and absolute geometry completion
First, about concentric circle parallel
May say like this that the straight line parallel is the concentric circle parallel special row, but the concentric circle parallel is the curve parallel special row. Curve parallel is general parallel, but the straight line parallel is quite special being parallel.
Below we have a look at the concentric circle the nature.
As shown in Figure 1, great-circle and small circle concentric, straight line AB and the great-circle have point of intersection C, straight line AB and the small circle have point of intersection D, straight line EF are the great-circle tangents, and D is a tangential point, straight line GH is the small circle tangent, and C is a tangential point, R is the great-circle radius, r is the small circle radius.
Supposition
β=∠BCH, α=∠BDF, β and α is the corresponding angle mutually, β is the great-circle corresponding angle, α is the small circle corresponding angle, G=CD.
Then
90-α=∠ADO
90+β=∠BCO
According to sine law:
R/sin(90+β)=r/sin(90-α)
After the reorganization,
R/cosβ=r/cosα
Reorganizes again
Rcosα=rcosβ (1)
By (1) obviously, when R and r tend infinite, the great-circle is the straight line, the small circle is also a straight line, β=α, this is also straight line being parallel. Therefore the straight line parallel is only the concentric circle parallel extreme.
According to law of cosines:
G^2=r^2+R^2-2rRcos(180-(90-α+90+β)
G^2=r^2+R^2-2rRcos(α-β) (2)
After reorganization (2) formula, obtains
cos(α-β)=(r^2+R^2-G^2)/2rR (3)
By (3) obviously, when R and r tend infinite, the great-circle is the straight line, the small circle is also a straight line, β=α (corresponding angle equal), this is also straight line being parallel. Therefore the straight line parallel is only the concentric circle parallel extreme.
We may say, in a plane, so long as G^2=r^2+R^2-2rRcos (α-β), then two circles are parallel (concentric), otherwise is not parallel (not concentric).
After the above discussion, the conclusion which I obtain is:
When straight line the line, the curve is also the line, the line including the straight line and the curve. The line may not by the understanding be a straight line merely.
In the curve, the circle is a straight line. The straight line is that kind of radius infinitely great circle.
The straight line may the mutually perpendicular, the curve also be possible the mutually perpendicular. (i.e., straight line may mutually parallel, curve may also mutually parallel). Is vertical including the straight line between vertical and between curve vertical.
The angle side may be a straight line, may also be the curve, the angle including the linear angle and the curvilinear angle.
In the plane, the curve triangle's angle's summation may be bigger than or be smaller than π.
The surface may also be parallel mutually.The concentric spherical surface is mutually parallel.
The spherical surface is in the space these maintains with the fixed point the parallel distance is the r these spot set.The spherical surface and the center are parallel.
Second, diagrammatic curve parallel
As shown in Figure 2:
In the plane, the rectangular two red side is parallel,
If we cause the rectangle to turn the cylinder, then that two red side is not parallel? I think them parallel, because between them the distance is constant.
If we cause the circular cylinder to turn the frustum, then that two red side is not parallel? I think them parallel, because between them the distance is constant.
If we cause the frustum to press the plane, then that two red side is not parallel? I think them parallel, because between them the distance is constant. (the attention, that two red side was precisely a concentric circle by now! ).
Therefore, once we acknowledge the straight line to be possible mutually parallel, then we can also not but acknowledge the curve also to be possible mutually parallel! The Euclid geometry only realized straight line parallel, but has neglected curve being parallel. He has received the historical limitation.
What is the parallel essence? This is the distance maintains constant invariable! No matter but whether is the straight line!
Third, about the non-Euclid geometry (including spherical geometry)
The spherical geometry thought that in the spherical surface does not have the parallel line. Actually this view is correct, is also wrong. In the spherical surface does not have the straight parallel line, but in the spherical surface actually has the curving parallel line. For instance, in the spherical surface latitude parallel is mutually parallel. Measures the grounding not mutually parallel, but this was not equal to said that in the spherical surface other curves may not be mutually parallel.
In the plane, through a known straight line's outside spot, has a straight line and the known straight line parallel, this is correct. In the spherical surface, through a known curve's outside spot, has a curve and the known curve parallel, this is also correct. Therefore may not remove the axiom of parallels in the spherical geometry! Certainly may not remove the axiom of parallels in the hyperbolic geometry!
The non-Euclid geometry thought: Crosses a straight line spot to be possible to make two straight lines and the known straight line at least parallel, actually this is the idea has the question. First, this confused has been parallel with the concept which did not intersect, because did not intersect was not equal to that was parallel, (in the Euclid geometry, because was parallel is limited in straight line, but in straight line, did not intersect as if is parallel, but in curve, did not intersect not necessarily is parallel); Second, this has confused the straight line and the curve difference, because the non-Euclid geometry said the straight line is a curve in fact!
Fourth, about absolute geometry
After the above revision, three geometries will unify completely and fuse one to be overall, humanity's geometry henceforth only will then perhaps become the absolute geometry.
  • #45
I asked you, 42 posts ago, to state what definition of "parallel" you are using. Since you have refused to do so, I don't see how anyone can say anything sensible about your statements.
  • #46
Parallel is the distance maintains invariable, for example, between the distance maintains invariable, between the curve the distance maintains invariable, between the surface the distance maintains invariable and so on.
  • #47
Concentric circles are an example of parallel curves.
  • #48
You can see concentric circles as being parallel from the perspective of the centre of each circle (the distance from the first to the second circle is constant, as measured from the centre) but from another viewpoint (say, and observer looking towards both circles) then they are suddenly not following this rule.
From the centre of the circles viewpoint, this says in coordinate geometry that [tex]x^2+y^2=r^2[/tex] is "parallel" to [tex]x^2+y^2=R^2[/tex]
but from the observer which is found situated far along the y-axis (as to observe both circles head on) then he will see two circles as "parallel" if they are of the form
[tex]x^2+y^2=r^2[/tex] and [tex]x^2+(y-c)^2=r^2[/tex]
Now one property of parallel lines is that if line A is parallel to line B and line A is parallel to line C then B is parallel to C. Following this rule, this would mean that [tex]x^2+y^2=R^2[/tex] is "parallel" to [tex]x^2+(y-c)^2=r^2[/tex] ? This is why we give concentric circles a description other than "parallel". And we should keep it that way to avoid ambiguity.
  • #49
g037h3 said:
concentric circles are an example of parallel curves.
yes!
  • #50
Your understanding is not necessarily correct, like the chart shows, the left side two circles are parallel, but the right side two circles are not parallel. Why? Because the circle and the circle distance is dissimilar. The attention, I said am the center of circle and the center of circle distance.
  • #51
In group of concentric circles, if A is parallel to B, B is parallel to C, then A is also parallel to C.
  • #52
Your diagram doesn't express what I mentioned. So I took the liberty of explaining it to you in pretty pictures.
http://img691.imageshack.us/img691/9694/parallel.th.png
This diagram is supposed to be 2 dimensional.
In the first row of examples, the red and orange lines are of equal length. The circles are of the same size.
So when you say curves are parallel, we could be confused into thinking it's two circles above. How can we know you mean concentric circles? If you do mean concentric circles, then just say so. They already have a name for those so there's no need to try and label them as being parallel.
There are inconsistencies in trying to extend the meaning of parallel since it needs to hold for all cases. Clearly, from my diagram, if you consider it parallel to be the observer from a fixed point (as in the case of concentric circles) then why aren't two lines parallel if you observe them in the same way?
And to touch up on another point. When two parallel lines are transposed (moved) they are still parallel to each other. In your diagram, this rule breaks down. You move one of those concentric circles and suddenly they aren't "parallel" to each other anymore.
  • #53
I'm not sure that last point is exactly fair, because since a line is the same in homogeneous space, and distances between circles depend on their center and radius, it is much easier to claim that circles can't be parallel.
I stand by my previous post, concentric circles are parallel curves, but not parallel lines, because in mathematics lines are generally perfectly straight.
  • #54
The point is, using the term "parallel curve" creates an ambiguity as I've already shown, unless it's specifically defined to be one or the other - which it isn't.
What is wrong with sticking to the term "concentric circles" anyway? I could just as easily argue that parallel lines are also concentric lines. It's just silly.
  • #55
I don't disagree, but I feel that the main point of the thread is to assert that concentric circles are parallel, which they are, because they're parallel curves. As long as the OP understands the difference between parallel lines (all the points that the line consists of can be rotated about themselves 360 degrees and the line remains parallel) and parallel curves, I don't really have a problem with the assertion.
  • #56
Ok but if concentric circles are parallel, then surely circles of the same size that have been transposed aren't parallel. But with this same property of transposition for curves, phya claims they are parallel too.
  • #57
I'm sorry, but could you please elaborate on what you mean by transposition? :)
My knowledge in this kind of topic comes from studying Heath's version of Euclid's Elements, btw. I'm only about 10% through it, but it is a very beautiful book.
  • #58
Tranpose or to move something. To slide in other words.
  • #59
Oh, I thought you meant to switch position, which makes no sense, because concentric circles have the same center, so they can't change places.
Circles of the same radius that have been moved aren't parallel in the usual sense, I agree. But if you take the curve of the half-circle on the same side of both circles, obviously they're the same, so they would be parallel curves, no? As in, there is a 1 to 1 match-up between points on the first curve and points on the last curve in that the value of the shortest distance between points that have the same value on the curve relative to the rest of the curve remains the same. Or, simply put, the curves fit perfectly with each other if the distance between the points are reduced to zero.
  • #60
Yes, they're concentric circles. One property of concentric circles is that given some line that cuts through the centre of the circles, at the point where it intersects the circumference of each circle, the tangents made at those points will be parallel.
My parallel lines are concentric lines too in that case.
  • #61
"Concentric lines"...circles are concentric because of their uniform curve...two parallel lines cannot have any 'center', they can have a mid-point between them, wherein the group of all points that are halfway between the two lines create a new line that is parallel to both of the original parallel lines. Obviously.
I'm pretty sure that the strict mathematical definition of "line" always means a perfectly straight line, so I don't know what you could mean by 'concentric lines', as if this is true, only curves can be concentric from a particular point, in if the distance from the center is changed for one uniform curve to the distance (radii) of another curve, that both are exactly the same, in 2D space, with relation to the origin/center.
  • #62
So then you agree that "concentric lines" is absurd, since there are many flaws and counter-examples to it. The same deal with parallel circles applies here.
  • #63
You indeed have not understood my meaning. Must pay attention, we enter are not the familiar domain, therefore we are very easy to make a mistake. Must pay attention, we in exploration curve parallel, but is not straight line being parallel. In straight line parallel, after the straight line was parallel the migration, is still parallel, but in the curve - - circle was not that simple. We are conceivable, the straight line is the radius infinitely great circle, then what meaning the parallel motion straight line is? The parallel motion straight line is increasing or is reduced the circle (is certainly diameter infinitely great circle) the diameter. The concentric circle parallel migration is also so, is also changes the circle the diameter, but is not under the invariable diameter migration.
  • #64
I can honestly say I have no idea what you just said.
  • #65
Yes, concentric lines do not make sense, at least in Euclidean space, I agree.
I say that the argument with parallel circles is different than the obviously standard definition of parallelism (Playfair's axiom), because with parallel lines, the argument is meant for plane geometry, but can obviously be made to hold in 3D geometry. The same can be said for concentric circles -> concentric spheres, except that you must specify a 1 to 1 matching between points on each sphere, with the minimum distance value relationship that I mentioned above. With parallel lines, it is more of a conceptual consistency, with parallel curves it is always in relation to something else, if you ignore the superposition proof/argument.
  • #66
Well there's no problem defining concentric circles to be parallel, but the only use I see this having is for it to be a shortcut way of describing the property that the tangents on each circle are parallel.
  • #67
You in the past and in future border, therefore, on the one hand you acknowledge the curve parallel, on the other hand, you thought that the line is only a straight line. In fact, the line may be straight, may also be curving, the straight line is straight, but the line is not only straight.
  • #68
Ah, wait a sec. Are you approaching this with a specific use in mind? You should just think about the objects and their relationship(s).
Also, I also have little idea what the hell phya is saying either. :/ idk if he's using translation software or just has a problem with vocabulary or grammar
  • #69
Well, I personally use Archimedes' definition that a line is the shortest distance between two points, but here is evidence that the mathematical term 'line' refers to a straight one: http://mathworld.wolfram.com/Line.html
  • #70
Oh no not at all. Phya wanted to extend the definition of parallel to describe curves too, and I've given examples that have shown that for circles (which can be for curves too) you can think of parallel in different ways, depending on how you view it. This leaves room for confusion which is why one would need to define what exactly parallel for curves is and the properties that accompany it.
But I have thought about them. Their relationship is that they are concentric and one of their properties is that given a line cutting through the centre of the circles, at the points where it intersects the circumferences, tangential lines at those points will be parallel.
This doesn't mean I'm ready to accept a flawed definition of "concentric circles are parallel curves".
