hmparticle9
- 152
- 26
- Homework Statement
- Consider a hollow conducting cylinder parallel to the ##z##-axis, of radius ##a## and charge ##\lambda## per unit length surrounded by an outer hollow conducting cylinder of radius ##b## with charge ##-\lambda## per unit length.
(i) Find the field for all ##r##
(ii) What is ##\sigma##, the charge per unit area on the inner cylinder?
(iii) Consider the field between two cylinders when ##(b-a) << a## is very small and compare the field to that inside a parallel plate capacitor.
- Relevant Equations
- Gauss's law:
$$\int_{S} \mathbf{E} \cdot \text{d}\mathbf{S} = \frac{q}{\epsilon_0}$$
To make a start. In part (i) we can use Gauss's law to show that inside the smaller cylinder and outside the larger cylinder the field ##\mathbf{E} = 0##. I am not sure how to progress in the remaining case.
This is like the last problem I posted in the sense that I find it hard to get off the mark. Could you offer me some advice?
