Conceptual Heat X-fer Question (Steady state, liquid changing temp as it flows)
The discussion focuses on understanding the heat transfer equation for a liquid flowing through a tube with a constant wall temperature. The equation for heat transfer is derived from an energy balance involving mass flow rate and heat capacity. The main confusion arises from the logarithmic term in the denominator of the heat transfer equation, which is crucial for understanding the overall heat transfer process. Participants emphasize the importance of applying an energy balance to derive the correct equations. Clarification on these concepts is essential for reactor design applications.
MikeOngay
Not hw.. My teacher wants us to understand this as it is important for reactor design.
A liquid is flowing through a tube of diameter D. The inner wall of the tube is maintained at a constant temperature of Ts. The liquid enters at a temperature of Tw1and leaves at a temperature of Tw2. The heat transfer coefficient for the liquid under the conditions of flow is h. The length of the tube is L. Assume steady state. Show that the rate at which heat is transferred from the wall to the flowing liquid is given by
q=h (π D L)((Ts−Tw1)−(Ts−Tw2))/ln((TS−Tw1)(TS−Tw2))
I am trying to understand why the above equation is right, the only thing I can't seem to get is the ln of the bottom term, I understand the numerator, or atleast I think I do.
If you don't understand the denominator then you don't understand the numerator.
The starting equation for this derivation is:
WC_p(T(x+\Delta x)-T(x))=\pi D \Delta x h(T_s-T(x))
where W is the mass rate of flow and Cp is the heat capacity. Do you understand where this equation comes from?
Divide both sides of the equation by delta x, and take the limit as delta x approaches zero. What differential equation do you get?
Chet
This is embarrassing but I realized that I wasn't using an energy balance while trying to solve for the heats...
Thank you!
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
