- 5,844
- 551
A cone of height h and base radius R is free to rotate about a fixed
vertical axis. It has a thin groove cut in the surface.
The cone is set rotating freely with angular speed ω0 and a small block
of mass m is released in the top of the frictionless groove and allowed to
slide under gravity. Assume that the block stays in the groove. Take the
moment of inertia of the cone about the vertical axis to be I0.
(a) What is the angular velocity of the cone when the block reaches
the bottom?
(b) Find the speed of the block in inertial space when it reaches the
bottom.
My issue isn't really with solving the two parts because that part is quite straightforward. Just apply conservation of angular momentum about the axis of rotation for part (a) and then conservation of energy for part (b). My problem is more with this: since there is never a presence of a net torque about the axis of rotation, [itex]\partial _{t}L_{y} = 0[/itex] (taking the y-axis to be the vertical axis of rotation) so, since the block and cone become one combined system much like in a perfectly inelastic collision, [itex]I_{0}w_{0} = (I_{0} + mR^{2})w_{f}[/itex] and we can easily solve for the final angular velocity of the combined system which is equivalent to the final angular velocity of the block. My question is simply: where does the angular velocity of the initial cone without the block go? At the end when the block reaches the ground there is obviously a loss in the angular velocity of the system from before the mass was placed on the rotating cone. I'm not sure where the angular velocity actually goes. Using conservation of energy I got that [itex]v_{f} = \sqrt{\frac{I_{0}}{m}(w_{0}^{2} - w_{f}^{2}) + 2gh}[/itex] and since [itex]w_{0} >= w_{f} >= 0[/itex], [itex]w_{0}^{2} >= w_{f}^{2} >= 0[/itex] so unless the rotation was zero to begin with (in which case vf is just sqrt(2gh)), there is a positive term that adds on to the 2gh term so am I right in saying that the loss in angular velocity simply gets added to the translational velocity of the block? It seemed too obvious so I don't know if there is some shady business here (=p). Thanks!
