Conceptual question concerning work and nonconservative forces
The discussion revolves around understanding the work-energy principle in the context of a box being pushed with friction involved. The key relationships being analyzed include the work done by the person pushing the box, the work done against friction, and the change in kinetic energy. It is clarified that the work done by the person is greater than the work done by friction, and that the net work done equals the change in kinetic energy. The confusion arises from the application of conservation of energy, with emphasis on distinguishing between conservative and nonconservative forces. Ultimately, the conversation highlights the importance of accurately interpreting these relationships in physics.
JYZero
Hi all. I feel silly for stumbling on such a simple question, but I can't seem to wrap my head about the conceptual aspect of it. The question is: A box that is initially at rest is pushed by a person at an angle (diagonally downwards), θ, with a force, F, until it reaches a speed, v. The coefficient of kinetic friction between the box and surface is μk. Which of the following relationships is necessarily true?
a) The work done by the person is equal in magnitude to work done by the friction force
b) The work done by the person is greater in magnitude than the work done by the friction force.
c) The magnitude of the work done by the person is equal to the change in the kinetic energy of the box.
d) The kinetic energy gained by the box is greater than the energy dissipated by friction.
Net work = Work done by person + Work done by friction = ΔKE
When attempting to solve this problem, I got confused when rewriting the above equations, as well as whether or not there was conservation of energy here.
a) Wp + -Wf = ΔKE; This is false, as ΔKE does not equal 0.
b) Wp + -Wf = ΔKE; This is true, as ΔKE > 0.
c) Wp = ΔKE - Wf; This is false.
d) ΔKE - Wp = -Wf; This is true.
As you can see, I seem to have made an error somewhere in converting these qualitative statements into their quantitative counterparts. I know A and C are false, but B and C seem to be saying very similar things.
One last approach I used was the conservation of energy theorem, but I don't even know how to set it up right, because my book simply states it as :
Wnc = ΔKE, meaning
Wf = ΔKE
But this doesn't make sense at all, when I compare it with the original work energy theorem.
Thanks!
You have it down pretty well. What you're missing is the possibility that the work done by the person and the work done by friction are pretty close. Say the person does 11 J of work and friction does -10 J. Look at (d) again with that example.
Okay, now I see. Thinking physics in words makes things confusing sometimes, haha.
Wnc = ΔKE, meaning
Wf = ΔKE
Here, Wnc = Wp + Wf (where Wf<0). The applied force isn't a conservative force.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
