Conduction and displacement currents for a spherical solid
In summary, the problem involves a spherical radioactive solid emitting charged particles radially outwards, but the conduction and displacement currents cancel each other out due to local charge conservation and the relationship between ##j_d## and ##\mathbf{D}##.
Huan Nguyen
Show that the conduction and displacement currents cancel each other for a spherical radioactive solid emitting charged particles radially outwards
Maxwell's equations
Current density (j)
Displacement current density (jd)
I haven't made it very far into the problem. I think "the conduction" means i=dq/dt and "displacement current" id=jd*S with jd= ∂D/∂t. However, I am still struggling to understand the problem.
Hello, Huan. Welcome to PF!
Every volume element of the sphere will be continually emitting charged particles due to the radioactive decay. The emitted particles are assumed (unrealistically) to stream out radially without being reabsorbed anywhere in the sphere. So, as the sphere emits particles the sphere builds up charge. Charge must be conserved locally and this can be used to relate the radial conduction current density, ##j_r##, to the charge density, ##\rho##, of the sphere. There is a well known formula for local charge conservation.
As you noted, the displacement current, ##j_d##, is related to ##\dot{\mathbf{D}}##. You'll need to relate ##\mathbf{D}## to ##\rho##.
Related to Conduction and displacement currents for a spherical solid
1. What is the difference between conduction and displacement currents?
Conduction currents refer to the flow of charge through a material, while displacement currents refer to the displacement of electric field lines. Conduction currents are caused by the movement of free electrons, while displacement currents are caused by a changing electric field.
2. How do conduction and displacement currents affect a spherical solid?
In a spherical solid, conduction currents will flow through the material, while displacement currents will be present at the surface of the sphere. This is because the surface of the sphere is where the electric field lines begin and end, leading to a non-zero displacement current.
3. Can displacement currents exist in a perfect conductor?
No, displacement currents cannot exist in a perfect conductor because a perfect conductor has an infinite conductivity, meaning that any electric field inside it would be immediately canceled out by the movement of charges. Therefore, there would be no changing electric field to cause a displacement current.
4. How are conduction and displacement currents related to the continuity equation?
The continuity equation states that the rate of change of charge within a volume is equal to the net current flowing into or out of that volume. Both conduction and displacement currents are included in this equation, as they both contribute to the flow of charge through a material.
5. What is the role of conduction and displacement currents in electromagnetic waves?
In electromagnetic waves, the electric and magnetic fields are constantly changing, leading to a changing electric field which in turn causes a displacement current. This displacement current, along with the conduction current, helps to propagate the electromagnetic wave through space.
