Conductors with off-centered cavity
  • Thread starter Thread starter raging
    Cavity Conductors
In an uncharged solid spherical conductor with an off-center cavity, placing a charge inside the cavity leads to an electric field outside the conductor that behaves as if the conductor were a charged sphere. Gauss's law can be applied to demonstrate that the electric field outside is determined solely by the total charge enclosed, regardless of the cavity's position or shape. The induced charges on the inner surface of the cavity balance the charge placed inside, while the outer surface of the conductor acquires a corresponding charge to maintain overall neutrality. This results in an electric field that is uniform and can be expressed as if the charge were at the center of a spherical conductor. Ultimately, the internal configuration does not affect the external electric field, confirming the uniqueness of the potential outside the sphere.
raging
Suppose we had an uncharged solid spherical conductor with radius R, and some spherical cavity of radius a that is located b units above R, where a+b<R. If we place a charge inside the cavity at the center, how would you quantitatively express the E-field lines outside of the conductor?
This is NOT a homework. Concentric cavities are too easy. I'm wondering if we can somehow apply uniqueness here to show that it actually doesn't matter where the cavity is...
The E field is easy to find using Gauss's law . And it doesn't matter where the charge is inside the sphere or the shape of the cavity.
Exactly. You can kind of reason it out in a way, by knowing that charges like to stay on the very outside of a conductor. Think about it, say you've got a positive charge inside that off-centre cavity. That charge is going to pull negative charges towards the inner surface of that cavity to balance it out. Then, to balance out those negative charges in the conductor, positive charges are going to show up on the outside of the sphere (regardless of where the cavity is), and they'll create an electric field outside the sphere exactly the same as if you had just a charged sphere.
You can use Gauss' Law to prove every part of that by setting up surfaces just outside the cavity and just outside the sphere and using the relation:
\Phi_E = \int\vec{E}\cdot d\vec{A} = \frac{q_{enclosed}}{\epsilon_0}
Where you know \vec{E} = 0 inside the conductor.
True. But to solve that surface integral simply one must apply a symmetry argument. How do you arrive about that symmetry? The induced charge will not be evenly distributed on the outside of the sphere, but is there a way to apply uniqueness to arguing that?
The outer surface of the conductor will be an equipotential surface of radius R. An outside potential phi=Q/r satisfies this boundary condition. It is thus the unique potential outside the sphere.
It doesn't matter what goes on in cavities within the conduciting sphere.
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
