Confidence Intervals for not integers numbers ratio
Calculating confidence intervals for binomial proportions can be challenging when dealing with non-integer values, particularly in cases involving background subtraction from simulated samples. The Clopper-Pearson method, typically used for integer ratios, may not be directly applicable to continuous numbers, raising questions about the theoretical justification for such calculations. A potential solution involves using the beta distribution, which may better accommodate the continuous nature of the data. It's suggested that if a sufficient number of events are present, conventional continuous methods could be applied despite the discrete nature of the original data. Properly accounting for uncertainties in the Monte Carlo background sample is also crucial for accurate efficiency calculations.
fatgianlu
Hi, I’m having a problem with a particular case of binomial proportion.
I want calculate a confidence Intervals for a binomial proportion for an efficiency. This kind of intervals are usually defined for ratios between integers numbers but in my case I had to subtract from both numerators and denominators some decimals numbers. I’d like to use Clopper Pearson method and I’m also able to extract the limits for these decimals numbers but I don’t know how to legitimise this calculation theoretically and if I can. Do you know if there is some way to threat confidence intervals properly using decimals numbers? Or some paper that talks about this issue?
It's not clear to me what you're asking. It might be helpful if you told us the problem you're trying to solve.
Likes mfb
Ok,
I'm calculating an efficiency to pass a selection of some data. In this data there is some background that I want to subtract. In order to do so I have a simulated sample of the background. This simualted sample is scaled with several weights. (normalization, efficiency correction, etc..) that leads to have not integers numbers. When i want to calculate the efficency, i.e. ratio between the successes in the trials, I have to cope with not integers numbers. When I want to calculate an uncertainty of a proportion I usually use the Cloipper-Pearson method that is derived form a binomial distribution. The binomial distribution is a discrete probability distribtion and so is not correct in my case where i have not integers but continuous numbers. What I'd like to have is a method to calculate a confidence-level in case of a proportion between continuous numbers. Or much better, a way to take into account a subtraction of weighted event. I read something about using the beta distribution but probably I should improve my stats knowledge... I don't know if the problem is clear.
That will be necessary, so I don't think the non-integer values are the main issue.
You can still use the basic approach: calculate efficiency values where the probability to observe more/fewer events than observed is below some threshold (2.5% or 5% or whatever). The probability will also have to take the background subtraction and its uncertainty into account.
How many events do you have? If you have enough, you can probably ignore the discrete nature of the observed events, and use conventional continuous methods.
Do you have proper uncertainties for the MC background sample?
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
