Chemistry Conformation Stability of Ethane-1,2-Diol
Torsional strain in ethane-1,2-diol arises from repulsive interactions between electron clouds, making rotation difficult. The presence of hydrogen bonds between alcohol groups allows them to attract each other, particularly in the gauche conformation. This configuration is more stable than the anti conformation due to the stronger hydrogen bonding when the OH groups are closer together. The hydrogen bonds effectively mitigate steric repulsion, facilitating easier rotation. Thus, the gauche conformation is favored for its enhanced stability.
EnricoHendro
Conformational studies on ethane-1,2-diol (HOCH2-CH2OH) have shown the most stable conformation about the central C-C bond to be the gauche conformation, which is 9.6kJ/mol more stable than the anti conformation. Explain the curious result.
No equations
Hello there,
My attempted explanation/solution is :
“Torsional strain is caused by the tendency of the electron clouds in the interacting groups to repel each other, making it relatively difficult to rotate a group towards and through another group, as the repulsive force provides resistance to the rotation. However, in alcohol groups, we have H-O bond. This means that the alcohol groups in ethane-1,2-diol can form hydrogen bonds with each other, and therefore “pulling” one another towards each other (since intermolecular force is an attractive force). This hydrogen bond is stronger when ethane-1,2-diol is in gauche conformation, since both OH groups are closer than in anti. In a sense, it is easier to rotate the compound in gauche conformation due to the help from the Hydrogen Bond. This explains why gauche conformation of Ethane-1,2-diol is more stable than anti conformation.”
Is my attempted explanation correct?
Sounds fine. More concise would simply be that the hydrogen bonding overcomes the steric repulsion in the gauche configuration.
Likes EnricoHendro
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
