Confused about answer key's solution to a work/energy problem
  • Thread starter Thread starter physics801
    Confused
The discussion revolves around confusion regarding the solution to a work/energy problem in a physics placement exam. The original poster questions why the solution manual uses (x_{max} - x) instead of (x - x_{max}) when calculating work done against gravity on a ramp. Clarification is provided that the choice of positive direction is crucial; if gravity is considered negative along the slope, then the positive direction is up the slope, affecting the sign in the equation. The importance of consistently defining positive and negative directions in physics problems is emphasized, along with the necessity of checking the signs of results. Ultimately, the poster acknowledges the misunderstanding and appreciates the clarification.
physics801
I'm studying for my college's physics placement and I'm frustrated because I don't get the solution to problem 1d.
The problem is here: http://ocw.edu.ht/courses/physics/8-01-physics-i-classical-mechanics-fall-1999/exams/exam_2.pdf
Solution manual is here: http://ocw.edu.ht/courses/physics/8-01-physics-i-classical-mechanics-fall-1999/exams/quiz2_sol.pdf
I drew a mspaint diagram of what I have: http://cl.ly/image/3b1o082l1k3a (x_{max} is defined in 1a, which is in the soln manual)
Basically since gravity is opposing the direction of travel (up the ramp), I think the solution to 1d(i) should be work=-mg(h-h_{max})=-mgsin\theta(x-x_{max}). However the solution manual has the same thing except x_{max}-x in the parentheses. Why is this? Shouldn't it be final - initial, which means x-x_{max} in the parentheses?
edit: I also have the same question for 1d(ii) and (iii) but hopefully it will be answered by explaining (i)
You have to decide which way is positive and stick to it.
If the force due to gravity is being taken as negative along the slope then the positive direction is up the slope. But x is measured down the slope, so it's (-x) - (-xmax)
It is always a good idea to sanity-check the sign of a result. It is clear that the work done by gravity here is negative.
Look at the direction of x, what does x mean in terms of the spring?
Oh whoops, I completely missed that. Thanks for the help!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
