I Confused by this armillary sphere in Australia
The discussion centers on the incorrect orientation of an armillary sphere in Australia, which is presumed to indicate a declination of -90. The axial arrow should tilt north at 23.5 degrees, positioning the torrid zone at the lower end and the temperate zone above it. Participants note that the color coding is also reversed, with "torrid" in blue and "temperate" in red, contrary to common conventions where hot is represented by red. This confusion in color and orientation highlights a significant misunderstanding of the sphere's intended representation. Overall, the armillary sphere's design fails to accurately convey its astronomical purpose.
swampwiz
I presume that the sphere is pointing at the declination of -90, and that the descriptions "torrid" & "temperate" correspond to tropic & non-tropic, respectively; as such, it seems that these descriptions are on the wrong sides.
https://en.wikipedia.org/wiki/Summer_solstice#/media/File:Longreach_at_Midday_of_Summer_solstice.jpg
Astronomy news on Phys.org
You are correct. They have made a muddle of the orientation.
The axial arrow should dip north at 23.5 deg, with most of the sphere on the lower, (equator), end of the axis. Then the torrid zone will be down axis, with temperate up axis to the south.
Baluncore said:
If you look here, you will see a different perspective.
https://foursquare.com/v/tropic-of-...254d8457?openPhotoId=52647444498e6bff66ac585e
Of course, "torrid" is in blue, while "temperate" is in red, which is the opposite of the standard idiom of hot=red, cold=blue. Of course, those of us that have deep understanding of physics (especially astrophysicists) would say that hot=blue, cold=red. :smile:
But their tropical sphere is painted red, so they reversed the convention when printing the torrid sign.
Likes collinsmark
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
