Engineering Confusing circuit analysis question
The discussion revolves around the confusion regarding the application of Kirchhoff's Current Law (KCL) in circuit analysis, specifically in relation to energy storage elements and state variables. The original poster questions whether their equation (4) is correct, given that they believe each energy storage element should have its own state variable. They express concern that using KCL at a node to relate currents seems to contradict this principle. A response clarifies that while each energy storage element has a state variable, these variables can be interdependent due to the interactions in the circuit. This explanation resolves the original poster's doubts about their approach.
anon6912
Thread moved from the technical forums, so no Homework Template is shown
Hi
I have the following situation:
(Please see attached pic)
I want to know if equation (4) i have written is correct.
What is confusing me is that, I remember being told in circuit analysis that each energy storage element should have its own state variable.
But in this situation when I apply KCL at node 1 and using that relationship I am seemingly able to write iL in terms of the other two variables.
I can apply KCL there can't I?
and if I can apply KCL at that node then I can get il = ig + is?
then I can substitute this result in eq1 to get eq4?
But this seems to violate what I have learned in class of each energy storage element needing its own state variable.
Any help is much appreciated.
Thank you
if we consider the current through each energy storing element as its state variable then I don't see what it is that bothers you.
Each element having its own state variable, doesn't necessarily mean that the state variables of various elements are independent from each other, the elements interact with each other with various ways when they are connected in a circuit in various ways, so their states become dependent from each other, so the state variables become dependent from each other as well.
Likes anon6912
Thank you. That clarified my doubt
Likes Delta2
Thread 'PLL - How to find all the gains of a PI corrector and fix Ki ? MATLAB'
Hello everyone, it's not really for my homework (because I'm not at school anymore) but I'm new and I don't know how to start a new forum. I've never done automatic before and I need help. I have a 2nd ordre PLL on MATLAB, with an NCO and a PI corrector; the PLL works via the Mid/End algorithm (that's part is ok). I need to find the link between the theoretical formulas and their values in the code to find the value of the gain Ki, and possibly that of Kp if it's not correct. Unfortunately...
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
