Confusion about nature of collision
The discussion centers on the nature of collisions, particularly the misconception that colliding masses must have equal velocities post-collision. It clarifies that momentum is conserved in inelastic collisions, not velocity, meaning outcomes vary based on the objects' characteristics. Deformable objects can absorb energy and change shape during collisions, affecting the resulting velocities and momentum transfer. The magnitude of impulse and force during a collision is also dependent on the details of deformation, which complicates predictions. Ultimately, there are no truly undeformable objects in the real world, as all materials exhibit some degree of deformation upon impact.
Inspiron
I have a problem with understanding the nature of collisions and their outcomes.
From my understanding, I come to think that when a mass collides with another, both of them should always have equal velocities post-collision. For example, when a mass moving at v1, m1, collides with a mass at rest, m2, their velocity after collision should always be m1v1 / m1 + m2. My justification for this is that once they reach that said velocity, they are not colliding anymore, they are moving along together, they have zero kinetic energy, relative to each other. I don't understand how is it that there are cases in which one mass loses it momentum completely to the other mass and other cases in which m1 may even rebound: how can any change in momentum still occur after they have equal velocities?
I also have problems understanding what governs the magnitude of impulse at collision: is it possible to predict the magnitude of the force and the duration of which the applied force will last? It seems, from all the problems on impulse that I have seen, it's impossible because the problems always have to give some information about the momentum pre and post collision, never only pre collision.
What am I failing to understand?
They can be deformed at that point, e.g. compressed in the direction of the collision. They "want" to retain their original shape again, which does not work without moving away from each other - there is still a force between them.
Only if you know details about the deformation of the objects.
Likes Chestermiller and Inspiron
I don't clearly understand.
So if two undeformable objects collides with another, will both of them always have equal velocities, as I said? And is there such thing as an undefromable object in the real world?
If two deformable objects collide, do they deform like springs, where kinetic energy is converted fully into potential energy and then into kinetic energy?
What are the details about the deformation should I know, and how is it used?
Thanks in advance.
No.
Remember that it's momentum that's conserved in inelastic collisions, not velocity.
The results of any collision between two objects will depend on the characteristics of the two objects. For example, if you stage a collision between a bowling ball and a small lump of sticky clay the two may stick together and have exactly the same velocity post-collision, but decidedly different momenta. Modern automobiles, for example, are designed to collapse so as to absorb energy and reduce momentum on both cars. It's not a simple issue.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
