Confusion over relative velocities and reference frames
In summary, the conversation discusses the concept of relative velocities and the difference between the relative speed between two objects and the speed of separation between them in a given reference frame. It is important to distinguish between the two and to consider relativistic velocity addition when calculating the actual relative velocity. The idea of one object being at rest in a given frame is not helpful in understanding the concept of separation speed.
etotheipi
I will refer to the example given in 'On the electrodynamics of moving bodies' concerning a rod moving in a coordinate system, in which a beam of light is sent from one end of the rod to the other and is then reflected back.
Usually when calculating relative velocities, we may simply consider the object the velocities are relative to to be at rest and go from there, so for example if an object A is at 3ms-1 and object B is at 5 ms-1, the relative velocity of B from A (taking A to be at rest in its frame of reference) is 2ms-1.
In the case of the rod, from the perspective of an observer in the stationary frame, a beam of light of velocity c traveling in the same direction of the rod of velocity v is given a relative velocity to the rod of c - v, in accordance with the relative velocity equation. However, I don't quite understand this in this context since if we consider the rod to be at rest - as we usually do when imagining relative velocities - the speed of light relative to it is c - v, and not c as implied by the axioms of special relativity.
My question is whether, in the stationary rest frame, when we calculate relative velocities are we 'still in' the stationary rest frame? That is, it is quoted in many places that the time taken for the beam to reach the end of the rod is (c-v)/L implying a relative velocity of (c-v) and length of L, however the notion of a relative velocity when we are in another reference frame is slightly confusing to me.
You need to distinguish two concepts, the relative speed between two objects, which is the speed of one of the objects in the rest frame of the other, and the speed of separation between two objects in some given reference frame. The speed of separation between a light signal and an object moving at speed v in some reference frame is c-v in that reference frame. The speed of light in the object's rest frame is c.
Likes etotheipi
You can take the difference between two velocities as measured in some frame S, yes. It gives you the separation rate between the two objects with those velocities, as measured in S.
This isn't the same as the velocity of one object as measured by a frame, S', in which the other is at rest. According to S, S' is using rulers that are length contracted and clocks that are time dilated and improperly synchronised, so it's no surprise that they measure a different velocity.
So the separation rate between two things may be anywhere between zero and ##2c## (for light pulses traveling in opposite directions). But the relative velocity as measured by one of the objects will always be below ##c##.
Likes etotheipi
Thank you both for your swift responses! This distinction makes a lot of sense.
Would I be right in assuming that, when using the speed of separation concept, it is valid to imagine it in a similar fashion to regular relative velocities (i.e. imagining that one object is not moving and saying that this separation speed is the speed of the other object moving past it), except keeping in mind that we are still in the original reference frame and that one object is not really at rest?
You need to let go of this notion if you want to look at separation speeds. It is not helpful for your understanding. But in general, yes, the separation velocity is the difference between the velocities of the objects and you can use regular subtraction to find it. When you look at the actual relative velocity, you need to consider relativistic velocity addition.
Likes etotheipi
Thank you very much, I have a better understanding now :smile:
Related to Confusion over relative velocities and reference frames
1. What is the concept of relative velocity?
Relative velocity is the measurement of the velocity of an object in relation to another object. It takes into account the motion of both objects and can be calculated by subtracting the velocity of the first object from the velocity of the second object.
2. How does relative velocity differ from absolute velocity?
Absolute velocity is the measurement of an object's velocity in relation to a fixed reference point, such as the ground. Relative velocity, on the other hand, is the measurement of an object's velocity in relation to another moving object. This means that relative velocity takes into account the motion of both objects, while absolute velocity does not.
3. Can relative velocity be negative?
Yes, relative velocity can be negative. This occurs when the two objects are moving in opposite directions. For example, if a car is traveling east at 50 km/h and a truck is traveling west at 30 km/h, the relative velocity of the car with respect to the truck would be -20 km/h.
4. How does the choice of reference frame affect relative velocity?
The choice of reference frame can greatly affect the measurement of relative velocity. If the reference frame is moving with one of the objects, the relative velocity will be zero. However, if the reference frame is stationary or moving with the other object, the relative velocity will be non-zero.
5. Why is it important to understand relative velocities and reference frames?
Understanding relative velocities and reference frames is crucial in many fields, such as physics, engineering, and navigation. It allows us to accurately calculate and predict the motion of objects in relation to each other, which is essential for designing and building structures, vehicles, and other systems.
