Congruent worldlines in "static" gravitational field
In summary, the study of congruent worldlines in a "static" gravitational field examines how the paths of particles with similar initial conditions evolve under the influence of a static gravitational potential. It explores the conditions under which these worldlines remain parallel and the implications for physical phenomena such as gravitational lensing and the behavior of matter in curved spacetime. The analysis emphasizes the role of spacetime geometry in determining particle trajectories and highlights the importance of understanding congruence in the broader context of general relativity.
  • #36
Ibix said:
The only assumption being made is that observers at any fixed ##z## always see the same result of any gravitational experiment.
I'm stuck with this point: observers at any fixed ##z## always see the same result only for local gravitational experiment. Is that true?
  • #37
I'm not sure what "local" is meant to mean in this context, honestly.
A simple experiment you could do is to drop a ball and time its fall. An observer at fixed ##z## in a static field who always releases the ball from rest and allows it to fall the same distance will always measure the same time. That is not a "local" result - the observer could let the ball fall 1cm or 100,000km and the time for the fall would not vary no matter how many times they repeated that experiment. That's the definition of static, really, that there is a family of observers for which this is true. Contrast with an observer who is changing ##z## slowly (in a lift, for example), who will eventually notice changing results as the experiment probes different regions of the field. Or contrast someone on Earth, who detects changing results due to the gravity of the Sun and Moon.
I suspect the point about locality is that if I drop a small ball through 1cm near my head and near my toes, I'll get the same results from each one (very nearly) on Earth, but very different ones if I'm hovering close to the horizon of a small black hole due to the tidak forces. The argument is that the head-height and toe-height experiments are the same but they give different results. Thus we say "local experiments" and say that near the horizon my head and toes don't count as local to each other. I prefer the view that the head-height and toe-height experiments are different ones always (albeit giving very similar results in weak fields). Thus I don't need the "local" restriction.
  • #38
How does the observer at fixed ##z## measure the time along the path the object is falling from rest ?
  • #39
Bounce a radar pulse off it. The nature of a static spacetime means that the radar pulse takes equal times on both legs of its journey, so you may not be able to measure distance accurately that way without further work, but you can determine at what time (by your clock) the echo happens.
Or you could measure the time from when you release the ball (right in front of your nose) to when you see it strike the floor. We don't care about the result, really, just the repeatability.
  • #40
I believe that's true only in the coordinate chart adapted to the hypersurface orthogonal's timelike KVF (i.e. in the coordinate chart in which the coordinate time worldlines are orbits of timelike KVF).
  • #41
Sure, but that's fine, as long as you use the same coordinates for each run. If you want something coordinate free, go with the "record the time you see it land".
  • #42
Do you mean record the time on the observer's clock at fixed ##z## when the radar pulse bouncing from the land event come back to the observer at fixed ##z## ?
  • #43
Yes.
