- #71
looking
- 45
- 5
looking, https://www.physicsforums.com/members/ato-automation.658170/ replied to a thread you are watching at Physics Forums | Science Articles, Homework Help, Discussion.
Please do not reply to this email. You must visit Physics Forums to reply.
Connect grid tied solar inverter to DC+ Bus of VFD?
![](https://physicsforums-bernhardtmediall.netdna-ssl.com/data/avatars/s/658/658170.jpg?1551686582)
looking
Just throwing this out for comment.
What about feeding two VFD's in series. The first one fed with a reasonable "abundance" of fused amps at rated full 480AC volts from the generator. First VFD would be programmed to control max current that the "grid tied solar inverter" can handle (which I guess is what Baluncore suggested in the last post). And then direct those first VFD output lines into the input of a second identical VFD, and then trying to do something with the DC+ voltage of the second inverter for any impedance mismatching?
The first VFD would be a good current limiter; but maybe just a good fault controller/detector for over current. Probably just a dumb idea but just throwing it out there. Maybe just another non starter idea. I'll look more into the Baluncore possibility of "programming a VFD to generate a constant output current, then rectify that for input to the "grid tie converter".
The Allen Bradley VFD's I'm looking at boast Common DC+ buses which can handle regeneration from other VFD motors etc. I'm not worried about losing 2% to 3% efficiency losses with each stage. Right now I'm wasting 100% of potential useful electricity.
.This reply made was apparently made
Man, do you have more inverters than you can use? Everyone in a inverter drag a few motors, you are 2 inverters drag a motor. You can try the inverter more, will burn the inverter, inverter output is not able to have current input. And ac series received if two phase opposite it becomes no voltage, is no electricity, if wave folding wave voltage double, your motor will be crazy, then smoking is small, inverter will fry it's difficult to say. END of REPLY
My response would be ...The only "load" was to be the "grid tie inverter". No motors would certainly have been a part of such an experiment.
However; for those interested...I will post an actual working solution which should/will impress any electrical engineer. It would be worth everyone's while to actually read that solution which is probably posted immediately below.
I do thanks those who actually did submit several suggestions that (trust me) were deeply appreciated... and without their help; I and one other person would not have come up with this solution that all other did not bring forth. Thanks to those persons.
looking
