Connect Multiple Devices with One Switch: An Electronics Question
  • Thread starter Thread starter Jelfish
    Multiple Switches
The discussion revolves around connecting multiple devices to a single signal source using a switch. The original poster sought a solution for switching between two devices without needing individual switches for each pin. Suggestions included using a 50 Ohm splitter if the devices and source matched in impedance, but more information about the signal type was needed for precise advice. Ultimately, the poster found they no longer needed the solution but expressed interest in a rotary switch for future use. Participants mentioned that pre-made switching boxes for various I/O ports are available online and at local electronics stores.
Jelfish
I'm not very experienced with electronics so this might be a simple question:
I have a tool that outputs signal information through a serial cable. I have two devices that connect with it, so I physically pull the plug and switch connections when needed. However, I would like to create a box with all three things connected and switch between the destinations with one switch. However, since there are several pins in use, I'm not sure how to do this without actually using a switch for each pin. Is there an easy way to do this? I would prefer to not have to power this switch also.
Thanks!
The answer depends on a number of things. Can you post more info (datasheets?) about the signal source and the two devices that monitor the signal?
Like, if the source and destinations are all 50 Ohms, then you can use a 50 Ohms splitter with a known loss to split the signals, and then just adjust your gain at the two receiving ends to account for the constant loss.
Is the data flow all one way, with no return information? Is the signal digital or analog? What is the bandwidth?
You have lots of options, we just need more info in order to be of help.
Thanks berkeman.
It turns out that I don't need this anymore. However, what I was looking for was something like a rotary switch, specifically a 6-pole 2-position.
Thanks anyway :)
Jelfish said:
Thanks berkeman.
Thanks anyway :)
You can get a box all made up with connectors and and appropriate switching for almosts any I/O port for a few dollars.
Really? Are you referring to a particular store or somewhere online? This may be useful in the future. Perhaps I should ask the local electronics shop.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
