Connecting a 5 pin nte7077 voltage regulator
The discussion centers around the NTE 7077 voltage regulator, a 5-pin IC used for regulating voltage at 110 volts with a tolerance of ±0.8 volts at a maximum of 1 amp. The user seeks clarification on the function of each pin, particularly the input, output, and control connections, as they aim to achieve a stable 110-volt output from a bridge rectifier. Concerns are raised about the safety of working with high voltage circuits, emphasizing the need for caution and understanding of safety protocols. The user confirms their application does not involve high voltage TV circuits and specifies a lower current requirement. Overall, the conversation highlights the importance of proper connections and safety in high voltage projects.
mrdryliner
I am working on a circuit. I have an IC bridge rectifier in place for ac to dc conversion at the proper voltage and amperage. I understand that the nte 7077 voltage regulator is for regulating voltage at 110 volts + or - .8 volts @ 1 amp max. This is a 5 pin IC regulator. I do not understand what the 5 pins are for. They show Pin 1 common ground. I get that. Pin 2 base? where would that be connected to. Pin 3 input? I assume that is the output of my bridge rectifier dc voltage which would vary with the ac voltage. Pin 4 output. I assume that is the 110 volt regulated supply. And Pin 5 output control? Do I need this? I want 110 volts regulated nothing else. could you help me understand how many of the pins I need to use and how to connect them to. Much appreciated! I'm new to the forum so I hope I'm posting in the right place. Thanks Again. Roy Andenmatten
Welcome to the PF.
The NTE datasheet is indeed sparse, and I didn't find any obvious Application Notes with a quick search. There are some alternate parts listed on this web page:
http://shop.vetcosurplus.com/catalog/product_info.php?products_id=5318
You might check into those part numbers to see if there are any good application notes.
I do need to ask what you are going to use this IC for, though. It's normally used in some pretty dangerous TV circuits. What are you trying to build, and what is your experience with high voltage?
Thanks for the reply, My application has nothing to do with high voltage tv circuits. It is limited to the 110 volts and is only running 0.5 amp with 1.0 amp circuit breaker. diodes are voltage sensitive and I want a steady voltage with a tight tolerance.
That is still enough voltage and current to be dangerous. It also sounds like you're plugging it into a wall outlet.
Please, be careful, and familiarize yourself with the relevant safety precautions.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
