Philip Koeck
- 712
- 198
I'm trying to sort out how the microcanonical picture is connected to the canonical and the grand canonical.
If I consider a Helium gas, not necessarily with low density, in an isolated container (fixed energy and particle number) I can use the microcanonical ensemble to arrive at the BE-distribution, and, in the low occupancy limit, the Gibbs distribution. The temperature and chemical potential arise from the Lagrange multipliers that account for constant energy and particle number.
Now, according to some authors, I can also select a small number of atoms and treat them as system and the rest of the gas as heat bath.
This means that there is no physical barrier between the system and the heat bath.
This system can exchange energy and particles with the heat bath and this leads to temperature and chemical potential.
If I work out the expected number of atoms in each energy level I again get the BE-distribution.
There is nothing special about the atoms in the system, so I could chose any small subset of the atoms in the whole gas as system.
Therefore whatever I find for the system should also be true for the heat bath.
Does this sound right so far?
Then I'll go a step further and decide that the system should consist of a single atom.
Is this still a normal and sensible thing to do?
The first problem I face now is that it doesn't make sense to allow for particle exchange with the heat bath, I believe, (since the system is supposed to contain a single atom). So, where does the chemical potential come from now?
