Connecting two rollers together
  • Thread starter Thread starter thoain14
To connect two conveyor rollers that are 2 ft apart, options include using a metal shaft or a torque tube, but care must be taken to avoid using a thin rod that could fail under torque. The rollers should be aligned correctly, and the bearings need to be positioned at the outer ends, not the inner ones. Alternative solutions include using stepped pulleys and belts to transfer motion or employing an electrical approach with a servo motor driven by a shaft encoder. The need for a connection depends on whether one roller drives the other and the specific torque requirements. Providing detailed dimensions and torque needs will help refine the best connection method.
thoain14
Hi there,
I have two conveyor rollers that are on the same plane about 2 ft apart. How can I connect their axles together while keeping that 2 ft distance? I was thinking of just getting a metal shaft and welding it together
Welcome to PF.
Are the rollers on the same axis ?
Free running conveyor rollers usually have a fixed shaft with bearings at each end to support the roller.
How are your rollers arranged?
Do they have internal bearings or are the bearings attached to the support frame.
Yes the rollers are on the same axis. I need to line them up side by side. The bearings will be at the outer ends of both rollers but not the inner ones. I need to somehow connect the two rollers together. From the top view, the order or parts will be Frame, Bearing, Roller, Something that connects the two, Roller, Bearing, Frame.
Replace the two rollers with a single length of the same size tube, to make one long roller. Keep the end bearings from one of the original rollers.
That seems to contradict itself. Side by side on the same axis, or end to end ?
Post a diagram or drawing of the roller positions and the bearing assembly.
It would be something along the lines of this. I did not want to use one roller because it would be so long. I was wondering if I was able to not use a bearing on the inside ends and figure out a way to connect them.
The simplest way to transfer torque between the two rollers is with a large diameter, thin wall, “torque tube”. When transferring torque, the material nearest the neutral axis is not helpful.
Your picture shows only a thin rod, which has only the material closest to the neutral axis. That is exactly the wrong way to do it. A thin rod would be a twist or torque spring and could easily fail. The rollers will need to slip against the belt to protect the connection rod from damage.
There are many other mechanical solutions. For example a stepped pulley on each roller, connected by a stepped belt, that passes around diagonal rollers, to turn the belt through 90° at each end.
There are also electrical solutions. For example, you could mount a shaft-encoder on the master roller, then drive the other roller with a servo motor as the slave.
Why do you need a connection?
Does the connection drive one of the belts from the other?
How much torque do you need to transfer between the rollers?
What are the length, diameter, and separation dimensions of the rollers?
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
