Conservation of Angular Momentum of merry-go-round
The discussion revolves around calculating the new angular velocity of a merry-go-round after a child jumps on it. The initial conditions include a merry-go-round with a moment of inertia of 250 kg*m^2, rotating at 10 rpm, and a child weighing 25 kg. Conservation of angular momentum is applied, leading to the calculation of the final angular velocity as 7.14 rpm when treating the child as a point mass. There is debate on whether to treat the child as a point mass or approximate its shape as a cylinder, with the consensus favoring the point mass approach for simplicity. The final conclusion emphasizes using the point mass formula for accurate results in this scenario.
nx01
A merry-go-round of radius 2m has a moment of inertia 250kg*m^2, and is rotating at 10rpm on a frictionless axle. Facing the axle and initially at rest, a 25kg child hops on the edge of the merry-go-round and manages to hold on. What will be the new angular velocity of the merry-go-round after the child jumps on?
Li (system) = Lf (system)
Let g = merry-go-round and c = child.
Li = Lf, so (IW)g-initial = (IW)g+c-final.
Solving for Ic:
Ic = mr^2 = (25kg)(2m)^2 = 100kg*m^s
Solving for Ig+c:
Ig+c = Ig + Ic = 350kg*m^s
Solving for final angular velocity of system:
W(g+c)-final = (IW)g-initial / Ig+c = [(250kg*m^2)(10rpm)] / 350kg*m^s = 7.14rpm.
My question is, should I be treating the child as a point-mass, allowing me to use I = mr^2 -- or should I approximate its shape in determining I? (Treating it as a cylinder - I = .5mr^2 - I get 8.33rpm.)
Any insight into this will be much appreciated!
hi nx01! :smile:
nx01 said:
… should I be treating the child as a point-mass, allowing me to use I = mr^2
yes :smile:
no, it would be I = .5mr2 + mR2
where r and R are the radius of the cylinder and of the merry-go-round, respectively :wink:
Thank you!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
