Conservation of Angular Momentum Problem with Rod and Bullet
The discussion revolves around a physics problem involving conservation of angular momentum with a rod and a bullet. The user is attempting to solve for the bullet's velocity just before impact after it lodges into a rod that can rotate about its center. They initially calculated the system's rotational inertia incorrectly but later realized the bullet's distance from the axis must be considered. Despite correcting the inertia formula, they still receive an incorrect answer in their submission. Additionally, the user encountered a technical issue with posting due to tag length limitations.
DoTell
Alright, this is my first experiment with this forum. Hopefully, I do this right!
I'm going to give the problem in terms of variables, not the numbers I'm given, so that people can't give me a direct answer.
A uniform thin rod of length (L)m and mass (M_R)kg can rotate in a horizontal plane about a vertical axis through its center. The rod is at rest when a bullet of mass (M_B)kg traveling in the horizontal plane of the rod is fired into one end of the rod. As viewed from above, the direction of the bullet's velocity makes an angle (A) degrees with the rod. If the bullet lodges in the rod and the angular velocity of the rod is (w) radians per second immediately after the collision, what is the magnitude of the bullet's velocity, (V_B)m/s just before impact?
Here's an image that is similar if it helps (with A=60 degrees): http://s3.amazonaws.com/answer-board-image/ec17a0c0-ec15-42e9-879e-d40b70321ef1.jpeg
Angular Momentum is conserved (Initial L=Final L)
Rotational inertia of a rod about its center: (1/12)MR^2
L=Iw=m(R x V)
First, I found the rotational inertia of the entire system: I=(1/12)M_R*L^2+M_B*L^2
Now I know the inertia of the system and can plug into conservation of momentum.
M_B*L*V_B*sin(A)=Iw
...and I can solve for V, which is (Iw)/(M_B*L)=(((1/12)M_R*L^2+M_B*L^2)w)/(M_B*L*sin(A))
When I input this solution into WebAssign, it's incorrect. Can someone pinpoint my error? Thanks in advance!
Also, anyone know about this error on PF? "You specified a tag that was too long. A tag can only be 20 characters." I had to remove all of the fancy tags to get this to post.
If L is the length of the rod, what's the embedded bullet's distance from the axis?
Not sure what you mean. Were you trying to use Latex?
Ah yes, that's a problem! I must use the radius for the bullet part of the total inertia. So the rotational inertia should be (1/12)M_R*L^2+M_B*(L/2)^2
But why is it still the wrong answer? If that's the only error, I must be making a computation mistake.
And about the tag error, I don't know, I just tried making subscripts and superscripts but it gave me that message as an error at the top of the page when I tried to preview it.
The same issue applies to calculating the angular momentum of the bullet.
Thank you very much!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
