Conservation of Energy: block on a table
In summary, the problem involves finding the work done, final velocity, and horizontal distance in a system with given values for mass, initial and final positions, and coefficients of friction and spring constant. After correctly computing the work and final velocity, the horizontal distance is found using the formula d = vxi * t.
Fatima Hasan
319
4nbh2228r
∑F=ma
W = - ΔUs
ΔUs = 0.5 k (xƒ)^2 - 0.5 k (xi)^2
W = ΔUs + ΔKE
d = viy t + 0.5 * t^2 * a
A) [/B]W = - (0.5 k xƒ^2 - 0.5 k xi^2)
= - (0-100)
W = 100 J
B)
W = ΔUs + ΔKE
100 = 0.5 m vf^2 -0 + 0 - 0.5 k xi ^2
100 = 0.5 * 2 * vf^2 - 0.5 * 2000*(0.1+1.5)
vf = 51.58
C)
∑F=ma
m a = - Fk + F spring
a = ( -4+200)/2 = 196 /2 = 98 m/s^2
0.3 = 0 + 0.5 * 98 * t^2
t = 0.078 s t = - 0.078 s ( unacceptable)
v = R / t
R = 51.58 * 0.078 = 4.04 m
Please check if it's correct or not.
Thank you
In general, you should write out your reasoning in words and properly define the notation you are using. Not doing so just makes your post difficult to read and decreases your chances of getting meaningful replies.
= - (0-100)
What numbers have you used here? Please show your entire computation.
Fatima Hasan said:
B)
W = ΔUs + ΔKE
vf = 51.58
You seem to be ignoring a crucial point of the problem statement, namely that the table is rough with a given coefficient of friction. Also, what is the 1.5 doing in your expression?
I tried to solve it again , here's my work
A)
xi = 0.1 m , xf = 0 m
Ug = 0.5 * k * Δx^2
= 0.5 *2000*(0-0.1)^2
= 10 J
B)
W = Fκd cos θ
Fk = FN μκ = mg μκ
W = 2 * 10 * 0.2 * 1.5 * -1
= - 6 J
W = ΔUg + ΔKE + ΔUs
Δ Ug = 0 (because the height doesn't change)
W = 0.5 k ( xf )^2 - 0.5 k ( xi )^2 + 0.5 m (vf)^2 - 0.5 m (vi)^2
-6 = 0.5 * 2000* (0)^2 - 0.5 * 2000( 0.1 )^2 + 0.5 * 2 * ( vf )^2 - 0.5 *2*(0)^2
v f = √ ((-6+10) / (0.5*2))
v f = 2 m/s
C)
(vfy)^2 = (viy)^2 + 2 a d
(2)^2 = 0 + 2 *a * 1.3
a = 4 / (1.3 *2 ) = 1.5 m/s^2
d = viy t + 0.5 t^2 * a
1.3 = 0 + 0.5 t^2 * 1.5
t = √(1.3 / ( 0.5*1.5)) = 1.31 s ( - 1.31 s unacceptable)
vx = R / t
R = vx * t = 1.316 * 2 = 2.63 m /s
You have A and B right.
Is this supposed to be for the vertical direction? The 2 m/s is horizontal, and the vertical acceleration is known.
So , no need to use this equation .. I can find the answer by multiblying the horizontal velocity ( 2 m/s) by the time ( 1.36 ) to get the horizontal distance . Isn't it ?
You used that (wrong) equation to get the (wrong) 1.316s.
Since the initial velocity of y component = 0 m/s ( we have only horizontal velocity ) and the vertical distance was given , so I can use this equation :
d = viy + 0.5 * a t^2
1.3 = 0 + 0.5 *10 * t^2 ( assume that downward direction is positive )
so , t = 0.5 s , t = -0.5 s --> invalid value
R = vx * t = 2 * 0.5 = 1 m
Am I right now ?
Am I right now ?
Looks good.
Likes Fatima Hasan
Related to Conservation of Energy: block on a table
1. What is the concept of conservation of energy?
The concept of conservation of energy states that energy cannot be created or destroyed, but can only be transformed from one form to another. This means that the total amount of energy in a closed system remains constant.
2. How does the conservation of energy apply to a block on a table?
In the case of a block on a table, the potential energy of the block due to its position above the ground is converted into kinetic energy when the block is released and falls to the ground. However, the total amount of energy (potential + kinetic) remains the same before and after the block has fallen.
3. What are some examples of energy transformations in the block on a table system?
Some examples of energy transformations in the block on a table system include potential energy being converted to kinetic energy as the block falls, frictional forces converting kinetic energy into heat energy, and sound energy being produced when the block hits the ground.
4. Is the conservation of energy always applicable?
Yes, the conservation of energy is a fundamental principle in physics and is applicable in all situations. However, in certain cases, it may seem like energy is not conserved due to the loss of energy in the form of heat or other forms that are not easily measurable.
5. How can the conservation of energy be useful in real-world applications?
The conservation of energy is essential in understanding and predicting the behavior of various systems, such as machines, engines, and natural phenomena. It also plays a crucial role in the development of sustainable energy sources and methods of energy conservation to minimize waste and reduce our impact on the environment.
