Conservation of Momentum for explosion
possum30540
A block moves at 5 m/s in the positive x direction and hits an identical block, initially at rest. A small amount of gunpowder had been placed on one of the blocks. The explosion does not harm the blocks but it doubles their total kinetic energy. After the explosion, the blocks move along the x-axis and the orginally moving block has a speed of:
momentum = mass * velocity
kinetic energy = (1/2) m *(v)^2
conservation on momentum: the total initial momentum = the total final momentum
since the mass of the two cars is the same, the mass = M
v1 = velocity of cart 1
v2 = velocity of cart 2
before the collision, the total kinetic energy is 12.5M J
before the collision, the total momentum is 5M kg*m/s
after the collision, the total kinetic energy is 25M J
initial momentum = final momentum
5M = Mv1 + Mv2
This is where I am stuck. I don't know what the next step is and if someone would help me along it would be very much appreciated.
You say that the total kinetic energy after the collision is 25M J. Write the equation fror that!
Likes novainkin
The problem says the initial kinetic energy is doubled. So 2 * 12.5 = 25 J
Yes, you said that before. Now USE it! Write the equation for total kinetic energy after the collision-explosion and set it equal to 25.
25 J = (1/2)Mv1^2 + (1/2)Mv2^2
Likes novainkin
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
