Conservation of momentum (should be easy)
An object with a mass of 16 kg and a speed of 19 m/s explodes in deep space, resulting in two pieces, one four times the mass of the other. The less massive piece stops relative to the observer, prompting a calculation of the kinetic energy added during the explosion. The original momentum was calculated correctly, but the final kinetic energy was miscalculated due to an error in summing the masses for momentum. The correct delta KE, after recalculating, is determined to be 722 J. The discussion emphasizes the importance of careful calculations in physics problems involving momentum and energy.
gbdusty
An object, with mass 16 kg and speed 19 m/s relative to an observer, explodes into two pieces, one 4 times as massive as the other; the explosion takes place in deep space. The less massive piece stops relative to the observer. How much kinetic energy is added to the system during the explosion, as measured in the observer's reference frame?
I calculated the original momentum, then i calculated the final momentum. I then solved for vfinal. I got 23.75 m/s for my vfinal. But now I tried calculating delta KE and I'm getting 1624.5 J, but my homework site is telling me it is incorrect. Can someone help me out?
I believe that your vfinal is correct, but you have probably made some stupid mistake with calculations at the end.
Initial kinetic energy is 0.5*16*(19)^2 and final KE is 0.5*(16/5)*4*(23.75)^2, and the difference, delta KE is 722J. Check it again!
Are you using the correct formula?
thanks i was adding both masses for the final momentum, that was my foolish mistake.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
