Consistency of the speed of light
In summary: It is important to note that theories require postulates. While it is theory that the speed of light is constant, for the sake of logical consistency, it is necessary to assume it to be universallly true for the sake of building other theories on it.
  • #176
Aether said:
Immediately following Eq. (5), Gagnon et al. state the following: “Substituting the usual solution for a plane wave traveling in the z direction, i.e., [tex]E(z)=Eexp(ikz-i\omega t)}[/tex] and solving for k, we find that the wave number corresponds to a wave with phase velocity c+v, to the first order of approximation. The classical velocity addition is thus obtained for electromagnetic waves moving in a reference frame.” Eq. (7) is given soon thereafter as:
[tex]k_g=-\frac{\omega}{c_0}\frac{v_z}{c_0}+\frac{1}{c_0}[\omega^2(1-\frac{v_x^2}{c_0^2})-\omega_c^2(1-\frac{v_x^2}{c_0^2}-\frac{v_z^2}{c_0^2})]^{1/2}[/tex] (Eq. (7)).​
This term in Eq. (7):
[tex]\omega_c^2(1-\frac{v_x^2}{c_0^2}-\frac{v_z^2}{c_0^2})[/tex]​
is invariant over rotations in the x-z plane, so we may simplify our analysis by applying Eq. (7) to the case of an unguided electromagnetic wave traveling in a vacuum along the z-direction of the laboratory-coordinate system (e.g., where [tex]\omega_c=0[/tex]):
Thank you, this is much better.
But [tex]\omega_c[/tex] is clearly not 0 in the experiment, so I cannot accept (7d). I thought that we were done with the ad-hoc invention of formulas, that you were going to rederive things from base principles. You come back with the same thing. can you solve partial differential equations?
K is the solution of the partiial differential equation (5), you cannot keep coming with cooked up formulas. If you want to refute the paper you need to solve (5) from base principles. I gave you a tool, the conversion to polar coordinates. On a different issue, k and [tex]\omega[/tex] are variables that get tied together by (5), so this should be your starting point, not all the different speculations as to how to connect the two, They are connected by equation (5).
  • #177
OK, I'm working up to that.
You said that [tex]k[/tex] was a "unit vector", but it is defined on p. 212 of ref (10) as: [tex]k^2=(\frac{\pi p}{a})^2+(\frac{\pi q}{b})^2[/tex] where p=1, q=0, (in this experiment) and (a,b) are the interior cross-sectional dimensions of a waveguide. Apparently, how the waveguide coordinates [tex](x,y,z)=(a,b,L)[/tex] transform over a rotation of the apparatus (combined with the one-way speed of light) is what ultimately determines the outcome of this experiment/analysis. We can expect that any anisotropy in the one-way speed of light due to RMS is going to be exactly offset by how these spatial coordinates transform; not so in Galileian relativity however.
This is how [tex]k[/tex] (in addition to the equation that I just gave) and [tex]\omega[/tex] are defined:
page 217 of ref (10) said:
...bearing in mind that [tex]k[/tex] is independent of [tex]\omega[/tex] and [tex]\beta[/tex]--it is a constant depending only on the mode concerned and the geometry of the waveguide cross-section.
The "mode concerned" is/are an integer(s), so [tex]k[/tex] varies with the geometry of the waveguide cross-section only.
pp. 1769-1770 of Gagnon et al. said:
Since it is phase locked to a reference oscillator which is at rest in the laboratory, the output frequency of the klystron [[tex]f=\frac{\omega}{2\pi}[/tex]] is unaffected by rotation of the apparatus.
  • #178
prior to einsteins special theory of relativity maxwell proved (theoretically) that the propogation of electromagnetic waves is 3.00*10^8 m/s (c = 1/sqrt(e0*u0)), all einstein did essentially in his special theory of relativity was expand galilean relativity(which stated something along the lines that the velocity viewed from different frames of reference will not be the same, but the laws such as the law of conservation of eneregy will still hold true in any inertial frame of reference) to say that all laws of physics hold true in all inertial frames of reference, and since maxwell's equations showed that the speed of light is constant it fell under the "all laws of physics"...im really sorry if someone else posted this argument before me, i didnt look through all the posts... hope this still helps answer your question
  • #179
clj4 said:
You come back with the same thing. can you solve partial differential equations? K is the solution of the partiial differential equation (5), you cannot keep coming with cooked up formulas. If you want to refute the paper you need to solve (5) from base principles.
I ordered a couple of advanced calculus textbooks to study partial differential equations in more depth; it will be at least a few weeks before I solve (5) for k. I think that I'll probably also need that to derive an anisotropic RMS transformation tensor for use with Eq. (6) from ref (9). I'll use that to transform both k and Eq. (8b) independent of Eq. (5).
In ref (10) the mode of the waveguide is identified by (p,q) rather than (m,n) as is used in Gagnon et al. (I will use (p,q) to identify the mode and reserve (m,n) for a different purpose), and on pp. 212-213 the cutoff angular frequency is defined as:
[tex]\omega_{pq}=[p^2\pi^2\epsilon \mu \frac{c_0^2}{a_0^2}+q^2\pi^2\epsilon \mu \frac{c_0^2}{b_0^2}]^{1/2}[/tex] Eq. (8b),​
where [tex]\epsilon \mu=1[/tex] for a vacuum “filled” waveguide.
According to Gagnon et al., Eq. (8) is supposed to transform a cutoff angular frequency [tex]\omega_{mn}[/tex] in the absolute frame into a cutoff angular frequency [tex]\omega_c[/tex] in a moving frame:
[tex]\omega_c=\omega_{mn}[1-\frac{v_x^2}{c_0^2}-\frac{v_z^2}{c_0^2}]^{-1/2}[/tex] Eq. (8);​
however, this seems to be inconsistent with the RMS transforms (their Eq. (1), also see post #92):
[tex]x=\gamma(x_0-vt_0),\ t=\gamma^{-1},\ y=y_0,\ z=z_0[/tex] Eq. (1).​
For example, with [tex](p,q)=(1,0)[/tex], [tex]\epsilon \mu =1[/tex], where [tex]a_0[/tex] is a distance along the x-axis and absolute motion is along the x-axis, then Eq. (1) transforms Eq. (8b) into Eq. (8c) (note that transverse wave motion is round-trip averaged):
[tex]\omega_c=\frac{2\pi c_0}{(a_0-vt_0)+(a_0+vt_0)}[1-\frac{v_x^2}{c_0^2}]^{1/2}=\frac{\pi c_0}{a_0}[1-\frac{v_x^2}{c_0^2}]^{1/2}[/tex] Eq. (8c);​
but Eq. (8) transforms Eq. (8b) into Eq. (8d) (the exponent in (8d) is of the opposite sign as in (8c)):
[tex]\omega_c=\pi \frac{c_0}{a_0}[1-\frac{v_x^2}{c_0^2}]^{-1/2}[/tex] Eq. (8d);​
  • #180
however, this seems to be inconsistent with their Eq. (1):
You are inverting (8b), right? I would expect to see a term in [tex]\omega_{pq}[/tex] in (8c). I am not seeing it. Could you show the steps, at a superficial view, if I look at (8b) and at (1), i would expect to see the exponent [tex]{-1/2}[/tex] in (8c)
Who are a0 and b0?
  • #181
No.
with [tex](p,q)=(1,0)[/tex], and [tex]\epsilon \mu =1[/tex]:
[tex]\omega_{10}=\pi \frac{c_0}{a_0}[/tex].​
[tex]\omega_{10}[/tex] is a cutoff angular frequency in the absolute frame, and [tex]\omega_c[/tex] is that cutoff angular frequency in a moving frame:
[tex]\omega_c=\frac{\pi c_0}{a}[/tex].​
To transform [tex]\omega_{10}[/tex] to [tex]\omega_c[/tex] using Eq. (1) we need to suppose that [tex]a_0[/tex] is a distance along the x-axis, and absolute motion is along the x-axis (this is necessary for now because Eq. (1) can only be used for motion and distance along the x-axis):
[tex]\omega_{c+}=\frac{\pi c_0}{\gamma (a_0-vt_0)}[/tex].​
However, [tex]a_0[/tex] lays along the x-axis while the wave propagates along the z-axis, and E reciprocates in the [tex]\pm x[/tex]-direction. So, this last equation only applies while the transverse wave motion is in the [tex]+x[/tex] direction; while the transverse wave motion is in the [tex]-x[/tex] direction this equation applies:
[tex]\omega_{c-}=\frac{\pi c_0}{\gamma (a_0+vt_0)}[/tex].​
Eq. (8c) is an attempt to compute the average of these two equations, and may change slightly if this average turns out not to be done quite right.
[tex]\omega_c=\frac{2\pi c_0}{\gamma((a_0-vt_0)+(a_0+vt_0))}=\frac{\pi c_0}{\gamma a_0}[/tex];
Who are a0 and b0?
[tex]a_0[/tex] and [tex]b_0[/tex] are the dimensions (in the absolute frame) of the interior cross-section of the waveguide. [tex]a_0[/tex] is taken to be along the x-axis, [tex]b_0[/tex] is taken to be along the y-axis. The electromagnetic wave propagates longitudinally along the z-axis. In a moving frame, these two dimensions transform to [tex]a[/tex] and [tex]b[/tex] respectively.
It is possible to compute [tex]\omega_c[/tex] and [tex]k[/tex] for a waveguide in a moving frame simply by transforming these coordinates (a,b).
  • #182
Thank you, I will check it out. At a quick glance the average doesn't look right, doesn't lok like an average. Have you considered checking ref 9, apparently they did all the support calculations there. Might save you a lot of time.
  • #183
Ref (9) should be very useful later, but it doesn't have anything to say about waveguides, [tex]k[/tex], etc. per se.
  • #184
I think I found the error. Omega transforms like 1/t so instead of 1/gama you should have gama in your formula
  • #185
[tex]\omega[/tex] transforms like 1/t, but [tex]\omega_{pq}[/tex] is defined by the spatial geometry of the waveguide (and the round-trip speed of light). It does seem strange, I also thought that it should transform like 1/t at first. We could leave that as an open question for now.
  • #186
No, we cannot leave it open, it is a clear error.
  • #187
It is a clear error on whose part? The boundary conditions on the waveguide "require the tangential component of the electric field in the laboratory frame to vanish at the waveguide walls", and this identifies
[tex]\omega_c=\omega_{10}=\frac{\pi c_0}{a}=\frac{2\pi c_0}{\lambda}[/tex],​
so:
[tex]\frac{\omega_c}{c_0}= \frac{2\pi}{\lambda}=k^0[/tex],​
which corresponds to the timelike component of a wave 4-vector [tex]k^\mu[/tex] and that transforms like [tex]t[/tex], right?
  • #188
jimmysnyder said:
That turns the whole idea of physical science on its head. No experiment can be devised that would prove any theory.
Sure there are experiments that can be devised to prove many theories, but this is not possible in the case of the postulate of SR regarding the constancy of the one-way speed of light. That is because all measurements of speed are inherently coordinate-system dependent. Doppler shifts, for example, are measurable in a coordinate-system independent way (e.g., [tex]\frac{v}{c}[/tex] is a coordinate-system independent dimensionless ratio), so you could actually prove something (within the limits of the precision of your measurements) by making such a measurement. The difference between coordinate-system dependent vs. independent measurements is what we're talking about here.
  • #189
Aether said:
Sure there are experiments that can be devised to prove many theories.
I deleted my post because it was redundant. Name a theory and the experiment that proves it.
  • #190
Theory: The Sun is made up of mostly hydrogen and helium; Experiment that proves it: spectroscopic analysis of sunlight vs. ionized hydrogen and helium. Duh.
You deleted your original post. If you still don't want to have this conversation (at least not here and now), then delete your second post too and I'll delete my responses.
  • #191
Aether said:
Duh.
I don't like the direction this discussion is taking.
All that your experiment proves is that there is something in or on the Sun that produces the same spectral lines as Hydrogen and Helium do on the Earth. An extraordinary coincidence indeed, but I'm afraid that does not prove your theory.
  • #192
OK, Theory #2: There is something in or on the Sun that produces the same spectral lines as Hydrogen and Helium do on the Earth; Experiment that proves it: spectroscopic analysis of sunlight vs. ionized hydrogen and helium.
  • #193
The experiment that you cite cannot have taken place since light from the sun is slightly red-shifted. The lines coming from the sun do not exactly match those of Hydrogen and Helium on the earth.
  • #194
The experiment has taken place, and as I said before "you could actually prove something (within the limits of the precision of your measurements) by making such a measurement".
  • #195
Aether said:
The experiment has taken place.
But the results were not as you claim. The spectral lines were not the same, just similar.
No amount of experimentation can ever prove me right; a single experiment can prove me wrong. -- Albert Einstein
  • #196
An experiment can change the status of an assertion from "hypothesis" to "likely to be true".
Note that this is in NO WAY WHATSOEVER a proof. Proof of some conjecture, in the mathematical (and the only relevant) sense, implies there is no way that some conjecture can ever be false.
Your statements about the spectral line merely say that at the time the experiment was done the measurements agreed with those that occurred on Earth (even assuming the light wasn't redshifted). However, to PROVE the conjecture, you would need to show that no matter when you did the experiment and under WHATEVER circumstance, you would still get the same results. There is no experiment that can ever do that to any theoretical conjecture or hypothesis. That is the status of theory or postulate in ANY empirical science.
  • #197
An unexplained center-to-limb variation of solar wavelength has been known for 75 years.
http://www.Newtonphysics.on.ca/Chromosphere/CHROMOSPHERE.html
  • #198
OK, there is a sense in which what you are saying makes sense: "Scientific theories are never proven to be true, but can be disproven. All scientific understanding takes the form of hypotheses, or conjectures" -- http://en.wikipedia.org/wiki/Theory. However, in the context of this thread and Einstein's quote that isn't what we're talking about at all. We are talking about something very specific, about whether it is possible (or not) to make a coordinate-independent measurement of the one-way speed of light. We all agree (at least for the purposes of this discussion) that we can measure the round-trip speed of light. If you want to argue that we really can't even measure the round-trip speed of light (or anything else for that matter), then please do that in another thread.
I interpret Einstein's quote as a warning that he is assuming that Lorentz symmetry is perfect, that no experiment can ever prove that it is perfect, but a single experiment could prove that it is not perfect. Not some general notion which would also apply to every other scientist in the world just as well.
  • #199
Aether said:
If you want to argue that we really can't even measure the round-trip speed of light, then please do that in another thread.
I didn't say that you can't do experiments. I said that you can't prove theories. It was in response to the original post in this thread.
  • #200
Hello, I've been watching this topic off and on for quite awhile now and it appears to be getting off track. I'm sorry to finally speak up on a note like this... but if it is possible, can we please focus on the issue at hand again?
It appears that this is what the topic started as. And it appears to be what you keep trying to return to. But I don't understand why all the calculations dealing with Gagnon's experiment are necessary for this topic.
You have argued your point well and clearly. I have seen no mathematically consistent argument against your statement that coordinate independent one-way velocity measurements do not exist.
So, to help clarify this long thread, has everyone come to an agreement on this main point and you have moved onto the specifics of one experiment?
Since it is easy to mathematically prove that coordinate independent one-way velocity measurements do not exist, if there is still a debate on this point, it would seem more appropriate to settle this simple question first instead of trying to do it with the messy details of just one particular experiment. Wouldn't you agree?
  • #201
Aether said:
I interpret Einstein's quote as ... Not some general notion which would also apply to every other scientist in the world just as well.
Here is a small sample of quotes I got off the net indicating that Einstein's quote is accepted in the larger context.
A theory is an explanation, a coherent set of ideas. They are not "proven," which tends to puzzle non-scientists. Theories can't be proven. They are accepted based on how well they are supported by empirical evidence, which is one of the reasons they change.
http://edstar.ncrel.org/mn/ViewEssay.asp?IssueID=37&EssayID=155
We can never be quite sure that we had indeed found the correct theory, since theories can't be proven.
http://www.spaceandmotion.com/Physics-Stephen-Hawking.htm
  • #202
Having slept on this, I came up with some ideas.
I am not a scientist. I agree with you that the theories I am familiar with from reading scientific texts are of such a universal nature that their proof would require the kind of universal experiment you describe. None-the-less, there is nothing preventing me from coming up with a less universal theory. For instance: "Last night, an electron hit the phosphorus on the screen of my TV, and I saw the resulting scintilation." However, the fact that I saw the scintilation does in no way prove the existence of electrons. That remains a theory. I saw a scinitilation. If I report more than what I actually saw, then whether I am aware of it or not, I am stating a theory. And to the extent that my theory differs, even by one iota, from what I actually saw, my theory is not proven. On the other hand, I can be more careful in the statement of my theory.
Snyder's Theory of Everything: "Last night, I saw a scintilation on the screen of my TV."
This won't do either. In the process of limiting my statement to what I actually saw, I have not a theory, but a fact.
Heads you win, tails I lose, for either way I have not proved a theory.
  • #203
That is because Gagnon et al. have published a paper in a respected physics journal that claims (or seems to) to have measured the one-way speed of light in a coordinate-independent way. There has been no rebuttal to their claims, at least not that has been published by the American Physical Society, so clj4 can point to their paper as evidence until it is refuted.
Thank-you. That's right, but the Gagnon paper stands until it is refuted, so we're sudying the details of the paper.
Not everyone has agreed on this main point. There are a half-dozen (or so) papers like Gagnon et al. that claim to have measured one-way speeds of light, and we may need to deal with each of them in turn.
Yes, I agree. If you would like to present such a proof, then please do so. However, these published papers that claim to have actually made coordinate independent one-way veocity measurements have to be properly refuted (especially if someone is insisting); wouldn't you agree?
  • #204
Aether said:
... so clj4 can point to their paper as evidence until it is refuted.
They measured basically no phase difference. Do we disagree with that? No, I don't believe anyone is disagreeing with their actual phase difference measurements at the moment. Our real complaint is in their calculations that claim this amounts to determining the universe's "real" synchronization convention.
And you have refuted this. You explained very clearly why such a measurement isn't possible. You showed that their paper's conclusions (not measurements) are wrong. Therefore if anyone wants to disagree the next step is for clj4 or others to counter your argument and so on.
Making both parties drag through the details of every paper is to lose sight of the main point. The best part about science is that we can work out the calculations ourselves. So, let's shed the experimental details, and come to agreement on whether a one way velocity can be defined independant of a coordinate system.
Then we can go back and approach the papers at our leisure if we want to nail down their error. To do it in the other order when the argument is so simple is just going to result in debating ad infinitum. Also, if one insists on doing it that way, the result never feels "convincing" since many detailed calculations were required and no insight into "why" it worked out this way can be seen. If one can make a general proof it is always preferred to working out every case individually. Besides, it is always best to understand the easy cases (which also happens to be the general case here) before burying oneself in detailed calculations.
Here, I will even help start this. Let me explain why no experiment can distinguish between "Generalized Galilean Transformations" and "Lorentz transformations".
1] There is one frame in which both theories agree on the form of every physical law. Perform the calculations in this frame to predict the result of the experiment. By definition the two theories must agree on the predictions.
Actually, that's it.
Or, here's a more specific case:
1] The time measured by a moving clock (in arbitrary motion) between two events on its path and coincident with its position are invarients in both theories (and both theories predict the same result).
2] Therefore all experiments measuring time differrences on a clock cannot distinguish between these two theories.
3] The two theories can agree on the spatial coordinates for all events.
4] Therefore any "measurement" of one way velocity which requires measuring time differences and length differences cannot distinguish between the two theories.
I can show the math for those steps if one really wishes, but given the statements from people so far, it appears we agree on those (which makes it confusing why we don't agree on the final conclusion).
So, clj4, please answer the following:
Question #1] Do you agree that one-way velocity cannot be defined independent of a coordinate system?
if not
Question #2] In my explanation of why experiments cannot distinguish between "Generalized Galilean transformations / coordinate systems" and "Lorentz Transformations / Special Relativity's" definition of the one way speed of light, which parts do you disagree with and why?
Thank you.
  • #205
That does very much sum up the problem. I think you refuse to accept that nature doesn't provide for observing such a measurement because it is all you have.
I don't think anyone can disagree that that aethereal theories of SR can be presented that does not contradict experimental evidence. The impossibility of your quote only expands the possible numbers of them. Choosing such a theory for purely biased reasons is not science but would be a valid logical exercise if your bias wasn't forcing you to cling to a dead horse.
Suppose for the sake of argument I had a theory that technically qualified as an ether theory and I could make the following true statements about.
SR is derivable 'AS IS'.
Mass energy equivalence is trivially derived.
Qualitatively conforms to GR 'AS IS'.
Reproduces the predictions of GR in the special cases checked.
Demands quantization of measurements.
The core equalities of QM trivially derived.
Provides opertional mechanisms for EPR without C violations as long as information is properly defined.
Demands things like DSR.
http://www.physicspost.com/articles.php?articleId=129"
The unobservables prevailant in such theories used instead to define and derive symmetries in the observable physics.
Etc, etc.
Do I have enough? No... Why? Where did I make even one prediction? Even DSR is a retridiction. Even though it's probably in principle falsiable I haven't supplied any method of doing so. Not to mention that I've failed to articulate any problems with it. So come on, back up and rethink your core assumptions. Articulate them PRECISELY right down to what an ether could be at it's most basic level. See if you can make something and quit hanging your hat on one unobservable concept. Or else you can be just another board spammer...
  • #206
You have this backwards. It is clj4 who has refused (so far) to accept this. Anyone else?
Please explain.
I predicted that the paper of Gagnon et al. wouldn't hold up to careful scrutiny, and I further predict that anyone who doesn't heed this lesson and produces a work in contradiction to the principles that we are discussing will fail.
I do have a personal theory that leads me to examine these false claims of coordinate independent one-way speed measurements, but this isn't a place for personal theories; and even if it was, there is a long incubation period for such a thing.
  • #207
Aether,
For havens sake, when are you going to see the light?
Which transformation is right? Lorentz or Mansouri-Sexl?
Do you still consist that they are not experimentally distinguishable?
Regard, Hans
  • #208
Hans de Vries said:
Aether,
Do you still consist that they are not experimentally distinguishable?Regard, Hans
Hello Hans,
Please show the details of how you're generating those graphs, and then show how to calculate the output of a hypothetical experiment from the equations. If you can show that different outcomes for an actual (hypothetical and idealized) experiment are predicted by the two sets of transforms, then I'll have to see the light. If you can't do that, then you'll have to see the light. Deal?
If you could set-up a simulation of the experiment as I did in post #164 (e.g., providing both the output and source code), that would be great. If you're not a programmer, then I'll write a program from your Latex (that is, if you still think that you have a valid point after reading what I have to say below about your wave drawings).
What are the horizontal and vertical axes in your drawings? I presume that absolute motion is along the x-axis, so the waves in your drawings are propagating back and forth along the y-axis? You only have the transformation equation for the x-axis to work with at the moment, so for now you must have both the longitudinal axis of wave propagation and the absolute motion along the x-axis in order to transform your experiment using the equations given. If you do that, you will see that the wave's round-trip travel time is predicted to be the same for both transforms. If you do not use a round-trip, then you'll also have to provide either a reference waveguide or a second clock/oscillator at the far end of the first waveguide.
  • #209
Aether said:
Hello Hans,
That's OK.
I was thinking in modifying my deBroglie wave program for this purpose
but I can just as well do this from scratch.
A laser gives a light pulse downwards vertically in the rest frame.
There's a mirror at the bottom which reflects the light back.
The laser can be made to co-move width the moving frame so that
it will stay at the same position in the moving frame.
Regards, Hans
  • #210
I write the program in the 3D raytracing Povray language which is simple
to follow and gives a very powerful visualization environment.
http://www.povray.org/
You can download and install the program for free here.
http://www.povray.org/download/
Then just copy and paste my program and click the RUN button.
Regards, Hans
