B Constant jerk motion: acceleration vs. position
  • B
  • Thread starter Thread starter FranzS
The discussion focuses on deriving an equation for acceleration with respect to position when motion involves constant jerk. The user proposes setting up a differential equation to relate acceleration and position, acknowledging the need to find time as a function of position, which involves solving a cubic equation. A response suggests using a known formula to solve the cubic and substituting the result back into the initial equations to find acceleration. The user realizes the oversight in not directly substituting into the first equation and appreciates the clarification. This exchange highlights the complexity of motion equations involving jerk and the importance of recognizing simpler solutions.
FranzS
TL;DR Summary
How to find an equation for acceleration vs. position in a constant jerk motion?
Hi PF,
a motion with constant jerk ##j##, i.e. with a constant rate of change of the acceleration with respect to time, should be described by the following equations (hope the variable names are self-explanatory):
\begin{cases}
a = a_0 + j \ t \\
v = v_0 + a_0 \ t + \frac{1}{2} \ j \ t^2 \\
s = s_0 + v_0 \ t + \frac{1}{2} \ a_0 \ t^2 + \frac{1}{6} \ j \ t^3
\end{cases}
I'm interested in deriving an explicit equation for acceleration ##a## with respect to position ##s## as the only independent variable. Jerk ##j## and all initial conditions are to be considered known values.
My guess is that I should set up a differential equation of the type...
\frac{da(s)}{ds}=\frac{da(t)}{dt} \cdot \frac{dt(s)}{ds}
... where ##da(t)/dt=j## by definition, and then integrate both sides.
But that would mean finding ##t(s)## first, and that's solving a cubic equation.
Is my approach correct? Is there any simpler way?
Thank you.
There's a known formula to solve a cubic. Look it up, write ##t(s)##, and plug that into your first equation. You will get either one or three real solutions. You can safely ignore complex solutions, but if you have multiple real solutions you may have to come up with a way to pick the correct one.
How could I not see the direct substitution into the first equation... It seems like I really wanted to re-derive that one as well... My bad. Thanks for pointing it out.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
