I Constant length metallic wire as a thermometer, using tension?
The discussion centers on the feasibility of using a constant length metallic wire as a thermometer, where the thermometric property is the tension of the wire. It is noted that the partial derivative of wire tension with respect to absolute temperature is negative for metallic wires, which raises questions about the relationship between temperature and tension. An empirical temperature scale is proposed, defined by the equation θ(ζ) = 273.16(ζ/ζ_TP), where ζ_TP is the tension at the triple point of water. The author queries whether this temperature scale could be considered "absolute," especially since it suggests that the boiling point of water would have a lower tension than the freezing point. The discussion seeks clarification on the validity of this reasoning and the nature of the proposed temperature scale.
zenterix
TL;DR Summary
Would it be possible to use as a thermometer a thermodynamic system consisting of a constant length wire by using the wire tension as the thermometric property?
I posted another question about a thermodynamic system with three coordinates, namely, that of a metallic wire. We can describe that system with temperature, wire tension, and wire length.
The result derived in that question was that the partial derivative of wire tension relative to absolute temperature (with length constant) is negative for a metallic wire (well, at least I think so, my question was precisely if this is the result obtained in the calculations I showed).
I also posted a question about thermometers and absolute temperature scales.
Can we use such a metallic wire as a thermometer, with the thermometric property being the tension?
Suppose the fixed length is L, and we determine the tension of the wire when the temperature is at the triple point of water. Call this tension ##\zeta_{TP}##.
Then, we change the temperature to some new equilibrium with a new tension. Now, at this point, I am using the word "temperature" without specifying if it is higher or lower than the initial state because we are in the process of defining the values of temperature.
Would we not have an empirical temperature scale defined by
##\theta(\zeta)=273.16\frac{\zeta}{\zeta_{TP}}##?
Now, this is still measured in Kelvin.
However, we would have, for example, the temperature at the boiling point of water being lower than the temperature at the freezing point.
Is this reasoning correct and would this temperature scale be considered "absolute"?
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
