Contact pressure of piston rod onto a surface?
The discussion focuses on calculating the contact pressure (P_contact) of a piston rod on a surface, given specific parameters including internal and external pressures, and piston radii. The calculated contact pressure is determined to be 1,080,000 Pa based on the force exerted by the piston. A dual piston setup is also considered, raising questions about whether the contact pressure on either side is halved, particularly when the area in question is a solid rather than a fluid. The participant clarifies that while the internal pressure remains the same, the forces on each side of the piston will differ. Overall, the calculations and assumptions regarding pressure dynamics in different configurations are central to the discussion.
randombill
I have two images below.
This is a single piston with pressure inside, the variables are as listed.
P_in = 2700 Pa.
P_out = 0 Pa.
R1 = Radius 1 = 10 cm.
R2 = Radius 2 = 5 mm.
P_contact = ?
My solution to P_contact is as follows.
Area A1 of piston at R1 = .0314m^2 and area A2 at R2 = 7.85x10^-5 m^2. The force exerted by P_in on the face of the piston with A1 is 84.78 N. Therefore P_contact = 84.78/ A2 = 1080000 Pa. I'm just wondering if this is correct?
My second picture has a dual piston setup and my question is whether the P_contact variable on either side is halved?
Assuming that the black area is a fluid, P_in will be the same as P_contact. The forces on the two sides will be different though.
Oh no, forgot to mention the black area would be a solid like steel or something. The Pressure for P_in would be due to a gas like air and the grey area would be a solid too like steel or wood.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
