Continuity on piecewise function
Wables
[10 Marks] At which points is the following function continuous and at which point is it discontinuous. Explain the types of discontinuity at each point where the function is discontinuous. Then at each point of the discontinuity, if possible, find a value for f(x) that makes it continuous or one sided continuous.
f(x) =
-2x if -1\leqx<1
-2/(x-1) if 1<x<2
x-2 if x> 2
Test continuity at point:
f(a) is defined
lim f(x) exists
x->a
lim f(x) = f(a)
x->a
Continuity at Endpoints
lim f(x) = f(a) = left continuous
x->a-
lim f(x) = f(a) = right continuous
x->a+
Im thinking what I need to do, is:
Check for continuity at the points -1, 1, 2.
Then I would classify any discontinuities as either removable, jump, or infinite discontinuities.
But that last part, I am not sure what its asking?
What I have is this so far:
Discontinuous at x=1 and x=2.
At x=1: Jump discontinuity
At x=2: Jump discontinuity
Im not sure if I am supposed to do this or if its right, but I did it anyway:
At x=-1, the function is right continuous on the interval [-1, 1). The function is also continuous on (1, 2) and (2, infinity)
Basically correct but the discontinuity at x= 1 is NOT a "jump" discontinuity:
\lim_{x\to 1^+} f(x)= \lim_{x\to 1}\frac{-2}{x- 1}= -\infty
Oh really? Cool! Thanks! So by stating the intervals of continuity, I satisfied the last part of the problem? Cause I was not sure what it was asking..
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
