Drakkith
Mentor
- 23,179
- 7,655
Gerenuk said:Because temperature is defined by T=dE/dS. And all equations are based on this identity. You cannot arbitrarily introduce a minus sign there. Or at least it wouldn't make sense, because you had to rewrite all the other thermodynamics equation and thus going back to negative temperature.
You misunderstand what I'm saying. The temperature is still a negative temperature. However, you can calculate the energy that the system would deliver to another system and from that you could convert that negative temperature into a positive temperature for use in the math.
For example, if a 500k system delivered 50 joules of energy to a 200k system, and -100k system ALSO delivered 50 joules of energy to a 200k system, then for the purposes of math you could simply insert 500k into all the spots where you would have put -100k.
200k(T1)/500k(T2) = Q1/Q2.
200k(T1)/-100k(T2) = Q1/Q2.
You could also rewrite this as 200k/500k=200k/-100k. In terms of energy content, then both 200k/500k and 200k/-100k would be the same in this circumstance.
If QH is the energy transferred from the hot resevoir, and QC is the energy being transferred to the cold reservoir, then:
QH in the 200k/500k system would equal QH in the 200k/-100k system. Its the same for QC.
Note that in relation to value of 200k for T1, if i used 300k instead then -100k would still impart 50 joules into T1, so you would have to change the value of T2 to a higher value that would transfer 50 joules into 300k. If we say that 700k would do that, then:
300k/700k = 300k/-100k.
The total amount of thermal energy transferred between the hot reservoir and the system will be: QH = TH(SB - SA) If TH is a negative value, then QH, the amount of energy transferred to the system would be NEGATIVE according to this equation. Obviously that doesn't happen because the value for TH is NEVER a negative value, as you cannot have less energy than absolute zero at 0K.
I am NOT saying that negative temp doesn't exist. The values used in the math represent the energy content of systems at those temperatures. THAT is what is key here. THAT is why you cannot use a negative value to calculate the carnot cycle, because you cannot have absolute NEGATIVE energy in any system. Negative temperature does not imply negative energy, but if you use a negative value for T in your math, then that is implying that you have negative energy.Now, before anyone takes 1 little snippet out of my entire post and try to use that to tell me why I'm wrong like what's been happening, I request that you do the math first. Goodnight all.
