Contradiction in laws of thermodynamics
In summary: At equilibrium, with an ideal gas and a simple model, the Kinetic Energy of the molecules (temperature) is the same, everywhere so there is none available for conversion to mechanical energy (to do work).
apurvmj
following is what little I know about energy:Energy: its the ability to do the work.
First law says you cannot create nor destroy energy but can transform it to from one form to another. so its always 100 % conversation. but in a process you have 'work' done also. so does that mean 'work' doesn't consume energy.
In second law; entropy always increase but cannot decrease. In other words system always tends to achieve thermal equilibrium. Does it mean at its peak you left no usable energy, why? when you have 100 % conversation or has energy got destroyed.
Thanks for your explanations (in advance)
Science news on Phys.org
If by "consume" you mean the energy ceases to exist, no.
For entropy, yes, it means temperature equilibrium.
* Work is energy flowing from one form to another. If for instance you push an object and it accelerates, its kinetic energy is increases because work has been done on it by the force that made it accelerate. But that energy must have come from elesewhere (The chemical energy in your mussels, for instance) so the total energy has not changed.
* Yes when entropy reaches its maximun, no usable energy is left. Energy is still conserved but it is in a format that canot be used any more.
Both your questions seem to be related to the stupid definition for energy given in introductory textbooks "Energy is the ability to do work". Dump that definition and you will be one step closer to understanding.
Energy is only 'available' to do work (a heat engine, for example) when there is a temperature difference. At equilibrium, with an ideal gas and a simple model, the Kinetic Energy of the molecules (temperature) is the same, everywhere so there is none available for conversion to mechanical energy (to do work).
I would not use the word "peak" in your original question. It's more of a limiting, maximum situation and will not decrease again.
Entropy does not reach an absolute maximum. The ability to use internal (thermal) energy (ie the ability to use thermal energy to produce mechanical work) just requires a temperature difference.
There is no need to change the definition of energy. Energy is the ability to do work. Work is the application of a force through a distance. Increasing the speed of a molecule requires work being done on that molecule. So it takes work to randomly increase the kinetic energy of molecules to increase temperature. This may not result in useful mechanical work on a macroscopic scale, but it still represents work being done at the microscopic level.
AM
The mean kinetic energy uniform throughout the system in equilibrium, but the velocities of the particles will still be characterized by a distribution function.
Your argument remains the same, but I think it's worth being careful about these things.
Agreed. I should have included the word 'mean' in there.
FAQ: Contradiction in laws of thermodynamics
What is the contradiction in the laws of thermodynamics?
The contradiction in the laws of thermodynamics refers to the apparent conflict between the first and second laws of thermodynamics. The first law states that energy cannot be created or destroyed, while the second law states that the total entropy of a closed system will always increase over time. This seems to contradict the idea that energy is conserved, as the increase in entropy leads to a decrease in the usable energy within a system.
How can the contradiction be resolved?
The contradiction can be resolved by understanding that the two laws apply to different systems. The first law applies to isolated systems, where no energy or matter can enter or leave. The second law applies to closed systems, which can exchange energy with the surroundings. Therefore, the decrease in usable energy within a system due to an increase in entropy is offset by an increase in entropy in the surroundings.
Can the laws of thermodynamics be violated?
No, the laws of thermodynamics are fundamental principles that have been consistently observed and tested in numerous experiments. They are considered to be universal and cannot be violated.
What are some real-world examples of the laws of thermodynamics?
Some real-world examples of the laws of thermodynamics include the conversion of chemical energy into heat and work in an internal combustion engine, the transfer of heat from a hot object to a cold object, and the conversion of electrical energy into light and heat in a light bulb.
How do the laws of thermodynamics relate to entropy?
The laws of thermodynamics are closely related to entropy, which is a measure of the disorder or randomness in a system. The second law of thermodynamics states that the total entropy of a closed system will always increase over time, meaning that the system will become more disordered and less organized. This is because energy naturally tends to disperse and become evenly distributed, leading to an increase in entropy.
