Control Theory -- Systems where the controller also changes with time
The discussion centers on exploring control systems where the controller's input changes over time, specifically incorporating the derivative of the control input, ##\dot{u}##. Participants note that traditional control theory often overlooks this aspect, particularly in linear time-invariant (LTI) systems. The conversation highlights the potential for creating state variables that account for the effects of ##\dot{u}## on the output, ##y##. An example involving the "D" component of a PID controller is suggested to illustrate the concept. Overall, the discussion emphasizes the need for further exploration of time-varying control inputs in control theory.
mad mathematician
Usually we look at a system of ODEs of the form:
$$\dot{x}=f(x,u,t)$$
$$y=g(x,u,t)$$
Why not look at systems where the controller also changes with time, i,e functions of terms ##\dot{u}##?
I took quite a handful of Control Theory courses and yet as of yet never seen one incorporating this derivative.
Perhaps it's impractical, my pure side of me doesn't really care though... :oldbiggrin:
I assume you are referring to LTI systems? Because you can construct all kinds of weird #$@! otherwise.
In the very sloppiest, hand wavy way (because it's late here and it's been a long time since I did this stuff for real), you will end up with a state variable that represents the effect of ##\dot u##, if it matters to the output ##y##.
Consider the "D" part of a PID controller:
https://ieeexplore.ieee.org/stamp/stamp.jsp?arnumber=9933758
Maybe try a simple example, like an RC HPF (in the EE context)? This stuff is often clearer when you work through a simple case.
Likes mad mathematician
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
