I Controlling the location of a spark between two parallel rods
  • I
  • Thread starter Thread starter Connor11
    Metal Spark
The discussion revolves around controlling the location of a spark between two parallel metal rods, one grounded and the other connected to ideal voltage supplies. The key concept is to utilize voltage waveforms to create a combined voltage that exceeds the breakdown threshold of air, allowing for precise control of the spark's location. It emphasizes the need for fast voltage pulses and accurate timing to achieve this, with a requirement for low-loss transmission lines to minimize pulse attenuation. The challenge lies in the rapidity of voltage breakdown and the propagation speed of the signals, which complicates achieving the desired precision. The conversation also touches on alternative methods, such as using specialized gas conditions to facilitate the ionization process.
Connor11
TL;DR Summary
two parrel rods, one grounded, the other has ideal supplies on each end, uniform dielectric
Imagine you have two metal rods that are perfectly parrel and separated in by a small distance. One is at ground potential. The other is connected on each end to ideal supplies. The supplies can deliver any voltage waveform you need no matter the current. You desire to change the location that the air ionizes and sparks by using the waveforms of the two supplies. Is this possible? My thought is that each voltage would be less than the breakdown voltage but through the propagation could combine to be greater than the breakdown threshold. I was thinking this problem needs a transmission line model but I don't know how to do that. I was trying to find what I need in Griffiths Introduction to electrodynamics but couldn't. Any recommendations on how to approach this problem or other E and M books to look into would be helpful. Thanks!
Alternatively;
Imagine a metal rod or line, above and parallel with a ground plane. You then have a transmission line over ground, with air (or a gas) as the dielectric insulation.
Place a signal generator at each end of the rod, to inject a signal into the rod, relative to the ground plane. We define the breakdown voltage to be 100%
If you generate a short 75% voltage-transient pulse into the line, it will propagate along the line until it is absorbed by, or reflected from the pulse-generator at the other end of the line.
If a 75% pulse is generated at the same time, at each end of the line, those pulses will pass somewhere along the line, where their voltages will be summed to 150%, which may break-down the air insulation.
Where those two pulses meet is decided by exactly when those pulses were launched.
To make that system work, it would require that the voltage pulse rises fast, relative to the time needed to propagate along the line.
It also requires the voltage breakdown of the air be well-defined and very fast.
To control the point of breakdown to within one foot, (300 mm), will require pulse-time accuracy, to be controlled to better than one nanosecond.
The line will need to be long. If the line is long, there will be attenuation of the pulse, that will require an initially higher voltage pulse. But the pulse cannot be more than 100% or the pulse generator will fail, so you need a low-loss line, with less than 3 dB attenuation along its length.
Which it isn't. The speed of transmission line propagation is much faster than arc creation. At least for voltages close to the breakdown threshold, as described.
Maybe standing waves, so the ions have time to collect?
Or "special" air preparation, like a thyratron or krytron, biased really close to avalanche and waiting for a trigger?
Connor11 said:
TL;DR Summary: two parrel rods, one grounded, the other has ideal supplies on each end, uniform dielectric
Would this be good enough? Jacob's Ladder will produce an arc that moves along a V shaped pair of conductors.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
