Conundrum of Solving True Anomaly in Binary Orbits: A Scientist's Dilemma
The discussion centers on solving the equation tan(v + ω) = tan(θ + Ω)sec(i) for true anomaly (v) in binary orbits. The initial attempts using v = atan(tan(θ + Ω)sec(i)) - ω and v = atan2(sin(θ + Ω)sec(i), cos(θ + Ω)) - ω are deemed ineffective due to quadrant issues and the direction of orbital motion. A convoluted solution referenced from a specific paper has not yielded results when implemented in Octave/Matlab. The user also mentions complications arising from having data for multiple orbits, which further complicates the problem. Assistance is sought to find a reliable method to solve for v given the constraints.
Rod_123
I have a real doosy that has got me stumped.
I need to solve the following equation for v:
The symbols stand for the following values in an elliptical orbit of one point source around another (on the celestial sphere):
where v = true anomaly; ω = argument of periastron; θ = position angle; Ω = position angle of the ascending node; i = orbital inclination (to line of sight)
The following obvious solutions don't actually work (at least not for every case):
I think the reason the first one doesn't work is to do with quadrant issues when taking the arctangent.
I think the reason the second one doesn't work has something to do with the direction of orbital motion. I've tried:
v = atan2(± sin(θ + Ω)sec(i), cos(θ + Ω)) - ω, but that doesn't work either in every case.
There is a convoluted solution on page 643 of:
http://ajbasweb.com/old/ajbas/2014/November/640-648.pdf
but try as I might I cannot make this work (in Octave/Matlab) and it does seem unnecessarily complicated.
Either way I've been working on this for weeks and just can't get it. Any help would be hugely appreciated.
Rod
Astronomy news on Phys.org
http://orbitsimulator.com/formulas/OrbitalElements.html
Here's a calculator I made that will do it for you.
But the method is a bit different. It computes it from the R and V vectors and the Sun's mu (G*M), rather than directly from the other elements.
You can view the source and read the javascript. Search for "var TA = arctan2(TAy, TAx);" and work backwards from there.
Thanks for the reply, but I can't see how this is relevant to my problem - that could be my fault though. They both involve arctangents but the knowns are different. All I know are the variables listed (except v of course) and the direction of motion/orbit (clockwise or anti). Another issue I forgot to mention that may be relevant is that in many cases there is data for more than one orbit. I've tried just selecting data for one orbit, but still doesn't work.
Oops, that should be: tan(v + ω) = tan(θ - Ω)sec(i)
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
