Convergence of Improper Integral
The discussion centers on analyzing the convergence of the integral ∫₀¹ (x² + 1) / (√x (1 - x)^(5/4)) dx. Initial attempts to split the integral into two parts led to confusion about the exponent calculations, particularly regarding the term x^(14/4) versus x^(13/4). The integrand behaves like 1/√x near x = 0, which is integrable, but as x approaches 1, the behavior changes, leading to divergence due to the term (1 - x)^(5/4). Ultimately, the integral diverges, and justifications for replacing integrands with simpler forms were discussed, emphasizing the need for inequalities to support convergence claims. The conclusion is that the original integral diverges.
pbialos
I have to analize the convergence of the following integral:
\int_0^1 \frac {x^2+1} {\sqrt x * (1-x)^{5/4}}
I tried to divide it between 0-1/2 and 1/2-1 and on the first one i reached to:
\int_0^{1/2} \frac {x^2+1} {\sqrt x * (1-x)^{5/4}}<=\int_0^{1/2} \frac {x^2+1} {x^{14/4}}
can i say that this integral converges and therefore the orgininal converges?, and more important, how would i justify that the last integral converges in an exam?
please correct any mistakes that i probably had made, and forgive me for me awful english.
Many Thanks, Paul.
How did you get that "14/4". If you just add the powers in the denominator you get 13/4. Are you arguing that \frac{x^2+1}{x^{\frac{13}{4}}}&lt; \frac{x^2+1}{x^{\frac{14}{4}}}?<br /> <br /> In any case, you can&#039;t just add the exponents like that. If x is close to 0, then <br /> 1- x is close to 1 and x<sup>2</sup>+1 is close to 1. For x close to 0, the integrand is close to \frac{1}{\sqrt{x}}= x^{-\frac{1}{2}}. And, of course, that integral exists. <br /> <br /> To look at what happens for x close to 1, it might help to make the substitution <br /> u= 1- x. Then x<sup>2</sup>+ 1= 2- 2u+ u<sup>2</sup> and the integrand becomes \frac{2- 2u+ u}{\sqrt{1-u}u^{\frac{5}{4}}. What is that like when u is close to 0?
The first integrand varies as 1/sqrt(x) near zero ( I checked what the expression becomes for small values of x by means of the power series expansion.) .So, the integral will converge or diverge according as the integral of 1/sqrt(x).It converges.
Similarly,to put in awful technical language, the integrand becomes
(1^2 +1) /sqrt(1)*( 1-x)^5/4 near 1 & diverges because the integral
dx/(1-x)^5/4 diverges if taken over a neighbourhood of 1.
These ideas must be put in terms of inequalities; e.g. in the first case, constants p & q could be found out such that p/sqrt(x) < the integrand < q/sqrt(x)
holds in a neighbourhood of zero.
I am, with great respect,
Einstone.
Don't know what happened to my first response- and no "edit" button to fix it!
What I was saying is that since x2+1 and 1- x are both close to 1 for x close to 0, the integrand is close to x-1/2 which is integrable.
If you let u= 1- x, then x= 1- u so x2+1= u2- 2u+ 1 and the integrand becomes \frac{u^2- 2u+ 1}{\sqrt{1-u}u^\frac{5}{4}}.
For u close to 1 that is close to \frac{1}{u^\frac{5}{4}} which does not converge.
thank you
First of all, thank you for your prompt and clear reply. I think i now understand how to do this exercise, but i don't know how to explain on a test why i can replace the integrands with another integrand that behaves the same way when x is close to 0 in the first part of the integral for example. I really don't understand the part of your explanation where you say that it can be found two constants p and q such that p/sqrt(x)<integrand<q/sqrt(x). I think that you are trying to show that i can replace the integrand by 1/sqrt(x)
but i don't know if it would be enough justification on a test.
Many Thanks, Paul.
Would this be sufficient:
\frac{x^2+1}{\sqrt{x}(1-x)^{5/4}}&gt;\frac{1}{\sqrt{x}(1-x)^{5/4}}&gt;\frac{1}{\sqrt{x}(1-x)^2}
for all x\in (0,1)[/tex]<br /> <br /> Making the substitution u=\sqrt{x} and using partial fractions, we obtain:<br /> <br /> \int \frac{dx}{\sqrt{x}(1-x)^2}=\frac{1}{2}\left[\frac{1}{1-\sqrt{x}}-ln(1-\sqrt{x})-\frac{1}{1+\sqrt{x}}+ln(1+\sqrt{x})\right]<br /> <br /> which diverges as x goes to 1.<br /> <br /> Thus:<br /> <br /> \int_0^1 \frac{x^2+1}{\sqrt{x}(1-x)^{5/4}}<br /> <br /> also diverges.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
