Convergent and Divergent Integrals
In summary, the divergent integral of \frac{1}{1 - x} does not converge. However, the improper integral with limits as \delta and \epsilon go to 0 independently does converge.
Anonymous217
355
I had a question regarding convergent and divergent integrals. I want to know the "exact" definition of an improper integral that converges. Wikipedia states that
An improper integral converges if the limit defining it exists.
For a while, I took that as a valid answer and claimed that any integral that has a finite answer must be convergent. However, I came up with a problem.
If you solve [tex]\int_0^2 \frac{dx}{1-x}[/tex], it turns out that it diverges twice, on both integrals (0 to 1, and 1 to 2). My textbook, which has never failed me so far, states that it diverges. Its solution solves only one of the integrals and it of course goes to infinity. Therefore, it diverges. However, if you solve the integral algebraically, you're left with [tex]ln|\dfrac{1-b}{1-b}|[/tex], which ends up being 0 as [tex]\lim_{b\rightarrow 1}[/tex]. Clearly, this integral has a limit that exists.
The problem lies in the fact that this integral "diverges" twice, at the same rate but in opposite directions. When evaluating this integral, this logically would lead to 0 because they're opposites of eacher.
What's your guys' opinions on whether this converges or diverges?
Maybe I do it differently, though. Could I write the integral as the limit as b approaches 1 of [tex]\int_0^{b^2} \frac{dx}{1-x} + \int_b^2 \frac{dx}{1-x}[/tex]?
Very interesting idea. That leads to [tex]ln|\frac{1-b}{1-b^2}|[/tex] which is [tex]-ln2[/tex] by L'H or simple canceling. That seems to make no sense at all, even though everything arithmetically looks right. A change in only one of the [tex]n[/tex]s for [tex]\int_0^{b^n}[/tex] or [tex]\int_{b^n}^2[/tex] changes the answer. Therefore, I would have to guess that doing so is not allowed. However, I'm only a high school student so I know next to nothing compared to you guys.
Huh?
The anti-derivative of [tex]\frac{1}{1 - x}[/tex] is [tex]-ln(1 - x) + C[/tex], which certainly does not have a limit as x goes to 1.
The problem is that infinity - infinity does not necessarily = 0.
Your problem could be reworded as the following integral:
[tex]
\int_{-1}^{1} \frac{1}{x} dx
[/tex]
Intuitively, both sides grow at the same rate but with opposite sign, therefore the integral is zero. This is where mathematical rigor > intuition. As it turns out, the integral is undefined (it's actually [tex]i \pi [/tex]).
You have to be very careful to see if the integral actually converges or not.
This is how I would do the math. I'm not saying that infinity - infinity is 0, but by using L'H and the difference of logs, you get an answer of 0.
[tex]\lim_{b\rightarrow0} \int_{-1}^b \dfrac{dx}{x} + \int_b^1 \dfrac{dx}{x} [/tex]
[tex]\lim_{b\rightarrow0} ln|x| |_{-1}^b + ln|x||_b^1[/tex]
[tex]\lim_{b\rightarrow0} ln|b| - ln1 + ln1 - ln|b|[/tex]
[tex]\lim_{b\rightarrow0} ln|b| - ln|b|[/tex]
[tex]\lim_{b\rightarrow0} ln|\frac{b}{b}|[/tex]
[tex]\lim_{b\rightarrow0} ln|1|[/tex]
[tex]0[/tex]
I'm guessing that I'm not allowed to cancel the b/b part?
The indefinite integral is NOT
[tex]
[/tex]
Rather, it's
[tex]
\lim_{b\rightarrow0} \int_{-1}^b \dfrac{dx}{x} + \lim_{b\rightarrow0} \int_b^1 \dfrac{dx}{x}
[/tex]
which does not exist.
Oh, I see. So you have to simplify each one separately and then add them together if they're finite numbers. Thank you for clarifying that.
It still gives me chills since by looking at the function graphically, it looks like it's 0. I agree with what L'h said though.
You don't simplify each separately. The first limit does indeed exist, and it's 0 as you pointed out.
The indefinite integral is said to exist if both limits exist, and in this case it's their sum. So when I say that it's the sum of their limits rather than the limit of their sums, it's a matter of definition.
An integral doesn't exist if the integral over any subdomain doesn't exist.
Torquil
Anonymous217 said:
I had a question regarding convergent and divergent integrals. I want to know the "exact" definition of an improper integral that converges. Wikipedia states that For a while, I took that as a valid answer and claimed that any integral that has a finite answer must be convergent. However, I came up with a problem.
But that is an incorrect calculation. The correct definition for such an improper integral would be
[itex]\lim_{\delta\to 0}\int_0^{1- \delta}\frac{dx}{1-x}+\lim_{\epsilon\to 0} \int_{1+ \epsilon}^2 \frac{dx}{1- x}[/itex]
with [itex]\delta[/itex] and [itex]\epsilon[/itex] going to 0 independently.
What you are doing is the "Cauchy Principal Value":
[itex]\lim_{\epsilon\to 0}\left(\int_0^{1- \epsilon} \frac{dx}{1-x}+ \int_{1+\epsilon}^2 \frac{dx}{1- x}\right)[/itex]
It definitely diverges by the definition of "improper integral" you will find in any Calculus text.
Okay, so the integral is indeed 0, but it diverges because if it diverges anytime within, it's a divergent integral. But HallsofIvy's definition for the improper integral makes it infinity - infinity and not 0?
No. The integral is [tex]i \pi [/tex]. The areas don't "cancel" out as intuition would tell you.
I'm completely confused now.. :(
Didn't Werg22 just say it was 0?
He said the limit was zero, yes. But that limit is not the integral as pointed out by Halls.
The limit of the sum is only equal to the sum of the limits if each of the limits converges.
Is this incorrect?
http://alt1.artofproblemsolving.com/Forum/latexrender/pictures/2/7/f/27f17cc7fd214c888358970d9c2aa16e9b3114eb.gif
Anonymous217 said:
Is this incorrect?
[/URL]
Sure. But...
What is
[tex]
\infty - \infty
[/tex]
This is why it's undefined and hence divergent.
okay! Thanks a lot guys! I really appreciate it. I guess I got stuck just because of the whole "limit on each integral separately" since my teacher never did that when we split up integrals.
This may be over my head and you guys already helped me out enough, but how do you show that it's [tex]i\pi[/tex]? I'm really interested. Does that involve Contour integrals or something?
This may be over my head, but how do you show that it's [tex]i\pi[/tex]? I'm really interested. Does that involve Contour integrals or something?
[tex]
[/tex]
Let [tex] x = -e^{i \theta} \ \ dx = -i e^{i \theta} [/tex]
Therefore,
[tex]
\int_{0}^{\pi} \frac{-i e^{i \theta}}{-e^{i\theta}} d\theta = \int_{0}^{\pi} i = i \pi
[/tex]
It beautifully swings around the fatal point x = 0.
Very cool! thanks.
l'Hôpital said:
[tex]
[/tex]
Therefore,
[tex]
[/tex]
You changed variables from a manifestly real variable to a complex variable, so there's no reason to expect this result to be correct. At best the result needs to be interpreted in the context of the complex plane.
Consider the contour integral [itex]\int dz/z[/itex] about a contour that begins at -1, goes to -[itex]\epsilon[/itex] near the pole at zero, but skirts above the pole in a semi-circular arc to [itex]+\epsilon[/itex], then to 1, then vertically up to a value [itex]Y[/itex], then horizontally back to -1, and then vertically down to close the contour. Since there are no poles inside the contour, the integral is zero. Decomposing it into components, the vertical ones cancel and we find
[tex]\int_{-1}^{-\epsilon} \frac{dx}{x} + \int_{+\epsilon}^{+1}\frac{dx}{x} = i\pi + \int_{-1}^{1} \frac{dx}{x+iY}.[/tex]
In the limit as [itex]\epsilon \rightarrow 0[/itex] and [itex]Y \rightarrow \infty[/itex], the result
[tex] \mathcal P \int_{-1}^{+1} \frac{dx}{x} = i\pi [/tex]
is recovered, but it is still a principal value integral, which is a different thing from
[tex]\int_{-1}^{+1}\frac{dx}{x},[/tex]
which strictly speaking doesn't exist.
FAQ: Convergent and Divergent Integrals
What is the difference between convergent and divergent integrals?
Convergent integrals are integrals that have a definite value when evaluated, while divergent integrals do not have a finite value when evaluated.
How can I determine if an integral is convergent or divergent?
One method is to evaluate the integral using appropriate techniques, such as integration by parts or substitution. If the integral has a finite value, it is convergent. If it does not, it is divergent.
What are some common examples of convergent integrals?
Some common examples include integrals with bounds that are finite, integrals with continuous and bounded functions, and integrals with integrands that decrease rapidly as the variable approaches infinity.
Can an integral be both convergent and divergent?
No, an integral cannot be both convergent and divergent. It can either have a definite value or not have a finite value when evaluated.
How are convergent and divergent integrals used in real-world applications?
Convergent integrals are used in many areas of science and engineering, such as calculating areas and volumes, determining the center of mass of an object, and solving differential equations. Divergent integrals are often used in theoretical mathematics and physics to study the behavior of infinite series and sequences.
