Converging Lens Homework: Finding Image Distance with Thin Lens Equation"
  • Thread starter Thread starter aChordate
    Converging Lenses
The discussion revolves around calculating the image distance for a new converging lens with a focal length of 32.0 cm, given an initial lens with a focal length of 11.0 cm that produced a real image at 25.0 cm. Using the thin lens equation, the object distance was determined to be 0.196 m for the first lens. For the second lens, the calculations yielded an image distance of -0.506 m, indicating a virtual image. Participants noted the importance of maintaining significant figures in calculations to improve accuracy. The final consensus is that the image produced by the second lens is virtual.
aChordate
An object is in front of a converging lens with a focal length of 11.0 cm. The lens
produces a real image located 25.0 cm from the lens. If the lens is replaced by a new lens
(in the same position) that has a focal length of 32.0 cm, what is the image distance of the
new lens? Is the image real or virtual?
Thin lens equation
1/f=1/d0+1/di
lens 1:
1/+11*10-2=1/dO+1/+25.0*10-2
dO=0.196m
lens2:
1/+32.0*10-2=1/0.196m+1/di
di=-0.506m
Virtual image
aChordate said:
lens 1:
dO=0.196m
lens2:
di=-0.506m
Virtual image
Your approach is correct.
Your answer is pretty close, but there are some rounding errors. You might want to try again, but keep more significant figures in the intermediate steps.
Likes 1 person
I got -.509 on the second try. Hopefully that is correct.
Yup. :approve: (Don't forget your units though.)
Likes 1 person
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
