Conversion of a trigonometic function
  • Thread starter Thread starter frensel
    Function
The discussion focuses on converting the expression tan(x)sin(x/2) + cos(x/2) into the form tan(x)/√(2(1-cos(x))). The initial steps involve using angle sum and difference identities to simplify the expression to cos(x/2)/cos(x). Participants suggest multiplying by sin(x)/sin(x) and applying half-angle identities to facilitate the conversion. The final result is achieved through a series of transformations, although one participant expresses concern over the complexity of the calculations. The conversation hints at exploring alternative methods, such as working backwards from the desired result.
frensel
How to convert
\tan(x)\sin(\frac{x}{2})+\cos(\frac{x}{2})
to
\frac{\tan(x)}{\sqrt{2(1-\cos(x))}}
I can convert it to this form: \frac{\cos(\frac{x}{2})}{\cos(x)}
=\frac{\sin(x)}{\cos(x)}\sin(\frac{x}{2})+ \cos(\frac{x}{2})
=\frac{1}{\cos(x)}\left(\sin(x)\sin(\frac{x}{2})+ \cos(x)\cos(\frac{x}{2})\right)
using angle sum and difference identities, we get
\left(\sin(x)\sin(\frac{x}{2})+ \cos(x)\cos(\frac{x}{2})\right) = \cos(x - \frac{x}{2}) = \cos(\frac{x}{2})
therefore, we have
\tan(x)\sin(\frac{x}{2})+\cos(\frac{x}{2}) = \frac{\cos(\frac{x}{2})}{\cos(x)}
hi frensel :smile:
hint: multiply by sin(x)/sin(x), and use the half-angle identities :wink:
tiny-tim said:
hi frensel :smile:
I got it, thx!
\frac{\cos(\frac{x}{2})}{\cos{x}}
= \frac{\sin(x)}{\sin(x)}\frac{\cos(\frac{x}{2})}{ \cos{x}}
=\tan(x)\frac{\cos(\frac{x}{2})}{\sin(x)}
using double-angle formula, we have
=\tan(x)\frac{\cos(\frac{x}{2})}{2\sin(\frac{x}{2})\cos(\frac{x}{2})}
=\tan(x)\frac{1}{2\sin(\frac{x}{2})}
finally, using half-angle formula (assuming \sin(\frac{x}{2})>0), then
=\tan(x)\frac{1}{2\sqrt{\frac{1-\cos(x)}{2}}}
=\frac{\tan(x)}{\sqrt{2(1-\cos(x))}}
Well, although I get the correct result, the calculation is so complicated. Is there any easier way to convert the above trigonometric function?
you could work backwards (from the answer) …
(tan / 2sin1/2) - cos1/2 = … ? :smile:
