MHB Converting between arcseconds and radians
  • Thread starter Thread starter viawilli
    Radians
To convert 0.05 arcseconds into radians, the formula used is θ'' = θ'' × (1'/60'') × (1°/60') × (π rad/180°), resulting in a conversion factor of π/648000. This calculation yields 0.05 arcseconds as approximately 2.42406841 × 10^-7 radians. Additionally, online tools like Convertin can facilitate quick unit conversions. Understanding the relationship between arcseconds, arcminutes, degrees, and radians is essential for accurate conversions. This method provides a straightforward approach to converting angular measurements.
viawilli
Hi i need to convert 0.05 arcseconds into radians and am not sure where to start any help is appreciated. thanks
Mathematics news on Phys.org
You could use:
$$\theta''=\theta''\cdot\frac{1'}{60''}\cdot\frac{1^{\circ}}{60'}\cdot\frac{\pi\text{ rad}}{180^{\circ}}=\frac{\pi}{648000}\theta\text{ rad}$$
Do you see how I used the fact that there are 60 arc seconds per 1 arc minute, 60 arc minutes per degree and 180 degrees per $\pi$ radians to construct 3 fractions all equal to 1 which I then multiplied with the original angle $\theta$, given in arc seconds, to obtain a conversion factor of $$\frac{\pi}{648000}$$?
You convert arcseconds and radians by using the specific formula. Like
0.05 arcseconds=2.42406841 × 10-7 radians.
The above is one method to convert, another method is you can also use convertin, which is used to convert the units online. By this you can quickly perform the conversion problems.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
