Converting PSD into equivalent sound pressure for an underwater hydrophone
  • Thread starter Thread starter nauman
To convert the measured PSD of -80 dBvrms/sqrtHz from the hydrophone output to equivalent underwater sound pressure level in dB re 1 µPa, the known sensitivity of -190 dB re 1 V/µPa and the preamplifier gain of 40 dB must be considered. The conversion involves adjusting the PSD value for the preamplifier gain and then applying the sensitivity reference. This process will yield the sound pressure level in the desired unit. Assistance is sought for the specific calculations involved in this conversion. Accurate conversion is crucial for underwater acoustics analysis.
nauman
Hi all
I have a underwater hydrophone with known receive sensitivity e.g. -190dB ref 1v/upa with a preamplifier having gain of 40dB at frequency e.g. 200Hz. I measure preamplifier output using spectrum analyzer and it gives PSD of around -80dBvrms/sqrtHz. I need to convert this PSD value into equivalent underwater sound pressure level with unit of dB ref 1upa.
Any help is much appreciated.
The measurement is of a single frequency, so that Power Spectral Density is not the appropriate measurement. All you need to measure is voltage. PSD is used for measuring noise like signals.
If you are actually measuring a noise-like signal, then the electronics must respond to the full sound spectrum and you need to know what the total bandwidth is.
If you have a narrow resolution bandwidth you can use that to convert the spectral density into a voltage. You can assume the psd is flat and just multiply by the measurement BW squared sqrt(BW). Of course the BW measured may only be part of the time domain signal.
For a more complex situation, it's like doing an inverse Fourier transform. It can't really be done without the phase information the spectrum analyzer threw out, but you could do the integral to get an estimate.
https://www.ti.com/content/dam/videos/external-videos/en-us/1/3816841626001/4078827152001.mp4/subassets/opamps-noise-calculating-root-mean-squared-noise-presentation-quiz.pdf#:~:text=To convert voltage spectral density to RMS,,to convert back to voltage or current.
edit: Oops! it's ##\sqrt{BW}## not ##BW^2##. Duh!, sorry
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
