Cooling Tower Sizing for 20 MW Power Plant in Weymouth, England
  • Thread starter Thread starter Harkaran Singh
    Cooling Sizing
Cooling towers are being considered for a 20 MW power plant in Weymouth, England, to efficiently manage heat rejection from the system. The required temperature drop for the working fluid is from 30°C to 19°C, with local wet bulb temperatures around 9°C and high humidity levels. Calculations for the cooling tower's size, mass flow rates, and make-up water are needed, and resources such as a design guide and cooling tower calculators have been suggested. There is also a discussion about utilizing waste heat for other processes, such as greenhouse operations, to enhance efficiency. Engaging with companies that specialize in cooling tower design is recommended for tailored solutions.
Harkaran Singh
Hi guys,
I have question regarding cooling towers. I have been asked to check if cooling towers would be efficient and economical to cooling system for a power plant to be installed in Weymouth, England.
As per my calculations, heat to be rejected (in the condenser) from the system is 20 MW.
I'm not familiar with cooling towers and I need help calculating (very roughly) the size of the tower required, parasitic loads, mass flow rate of water and air and quantity of make-up water?
Heat energy to be rejected= 20 MW
Temp of working fluid in the condenser has to be dropped from 30 deg C to 19 deg C
Wet bulb temperature of the area is 9 deg C
Avg temperature of area 14 - 16 deg C
Relative humidity is 85 - 90 %
Any advice would be highly appreciated.
Not my field but it seems a shame to be wasting 20MW these days. Got room for some green houses?
http://www.queensu.ca/gazette/content/waste-heat-could-be-harnessed-growing-tomatoes
http://www.gfsa.com/events/greenhouse-to-utilize-co2-waste-heat-from-adjacent-ethanol-plant/
Yes, I agree its a waste. I'm urging the people involved to use this heat in other processes at the site.
Area is a major concern here and that is the reason why I'm interested in the area the cooling tower would occupy
As I said it's not my field but I found a "rule of thumb" design guide from 1981 that I suppose might help. Not SI units though.
http://www.osti.gov/scitech/servlets/purl/5281927/
It also looks like there are companies producing calculators for their cooling tower products. I think I'd contact one or two that design these for a living to see what they would recommend. They would probably do most of the work for you.
Likes Tom.G and Harkaran Singh
This is really helpful. Thank you :D
That will be smart choice to introduce Cooling Water Towers with Calculator for quick note of issues
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
