Correct bore sizing for a shower hose for a pumped water supply
Correct bore sizing for shower hoses is crucial for optimal water flow, especially in pumped systems. There are conflicting opinions on whether to use larger 11mm hoses or smaller 8mm hoses, with some suggesting that larger hoses provide better flow rates. However, the actual performance can vary based on the specific shower head and system configuration. In this case, switching to a full bore 11mm hose resulted in reduced flow, prompting consideration of an 8mm hose for improved performance. Ultimately, the choice of hose size should align with the system type and desired flow characteristics.
reddwarf4ever
TL;DR
Please don’t laugh, this may sound a trivial question, but it is important. I have seen so many conflicting opinions, even from manufacturers. Some say, just use the biggest bore possible, others say use a small bore 8mm for a fully pumped system & a large bore 11mm for a gravity system. There must be a reason why different size bore hoses are manufactured.
I changed the shower hose yesterday, thinking it to be the same; although it did have a scale catcher fitted, which I discarded, to a full bore 11mm shower hose, but it appears the flow is now less, so should I change it to an 8mm bore to achieve the maximum flow rate.
Many thanks
Yes hot and cold are pumped,
What mathematics software should engineering students use? Is it correct that much of the engineering industry relies on MATLAB, making it the tool many graduates will encounter in professional settings? How does SageMath compare? It is a free package that supports both numerical and symbolic computation and can be installed on various platforms. Could it become more widely used because it is freely available? I am an academic who has taught engineering mathematics, and taught the...
  • · Replies 39 ·
15K
9K
11K
9K
  • · Replies 33 ·
